You can recreate that tensioner bolt easily at a hardware store, I'm going to guess M10-1.25 as most powertrain bolts are.
Anyone have the part number for the top idler (small cylinder shape with a center (shiny) metal strip? Is this pulley have replaceable bearings?
Yes-sealed, high temp, high load etc. Better than what came out. The one pulley has a snap ring and is easy to change the bearing. You will need to get creative with the other. I ground off the tiny tabs with a dremmel, pressed out the bearing and then drove the cover back in and secured the cover with 3 tiny spot welds. Sounds worse than it is.
There are piles of 6301 bearings. It's a very standard size. I ended up choosing the most durable sounding ones, that can take high heat too. Changing $10 bearings was easier than swapping $35 pulleys, which are not available from Toyota any longer. THe NSKs are made in Japan, sounded like the thing at the time and I've had no issues in 6 months. Time will tell, but I could swap again in a couple of hours so I'm not worried.
I'm gonna throw another wrench into the works here: On my '88 it has manually adjusted tensioners for both the A/C and the power steering belts. Then the alternator itself acts as a tensioner for its belt. The A/C tensioner has a vertical adjustment bolt and rides right next to the compressor, and the power steering has a horizontal adjustment bolt and rides a little ways underneath the PS pump.
Nah, it's not hard at all really. You just have to reach up from below to adjust it. Only caveat is you need a couple long extensions to easily reach the bolt.Like this - it is going to be bad news trying to tension that AC belt when I finally get space made for the compressor:
You shouldn't have to move the upper nuts at all. I didn't. By turning the bolt head (on the bottom of the tensioner) you'll turn the bolt, which will move the pulley up and down in its track. The bolt holding the pulley in place is what locks the whole assembly in place, so if you don't loosen it slightly you won't be able to make it move at all.
Do I need to come up to the Fort to show you what to do?
Crash, otherwise known as Overhanger.
just put some hair on it and git er done already....
I'll try to post some pics tonite...too dark to snap a few right now...napa makes the lines...
