2F-3FE engine combination = (2FE)
Regarding a 2F block and 3FE head: (Updated 3/8/06)
I have done a lot of research on the 2F and 3FE engines (FJ60, FJ62, FJ80) and found the following:
2F (I do not know what years of 2F engine this aplies to but I think it is for 1981-87)
bore x stroke = 94 x 101.6mm (From Toyota Factory 1988 update manual)
compression ratio = 7.8:1 (From Toyota Factory 1988 update manual)
engine head chamber volume 89.8089cc (calculated using flat pistons and 2mm thick head gasket)
4230cc = 258.1ci = 4.2L (From Toyota Factory 1988 update manual and calculations)
3FE (1988-92)
bore x stroke = 94 x 95mm (From Toyota Factory 1988 update manual)
compression ratio = 8.1:1 (From Toyota Factory 1988 update manual)
engine head chamber volume 78.9766cc (From Toyota Factory 1988 update manual and calculations)
3955cc = 241.3ci = 3.9L or 4.0?
Using this data, if you put a stock 3FE head on a stock 2F block you would get a compression ratio of
8.5933:1.
So here are my questions for the experts (because I do not have the engine manuals yet):
1)
I have heard that from 1980-1984 2F engines have a 2F head and 1985-87 2F engines have a 3F head.
So, does this mean that the 3f and 3fe head chamber size is different?
or
Is the compression ratio in a 1985-87 2F is 8.5933:1?
or
Did they change to a shorter piston to reduce the CR back down to 7.8:1?
or
Other?
2)
I know the 3fe pistons are shorter, can anyone tell me if they will fit on a 2f connecting rod (same wrist pin size?)?
What I found is that the pistons are not interchangeable because the piston type and diston in diameter size changed.
If they will fit can someone tell me how much shorter they are than the 2f pistons?
They will not fit.
Are both the late 2F and 3FE pistons flat? (FJ60, FJ62, FJ80)
Yes
3)
Has anyone driving a 2F block-3FE head engine had any problems with detonation?
What octane do you have to run?
(I found 1 person who runs 89 octane with no problems)
4)
Does anyone know how much more horsepower raising the CR to 8.5933:1 and adding fuel injection adds?
I am going to swap engines and I am trying to figure out if I should do the combo or just put the stock 3FE in my fj60.
Other notes:
Measurements of the height of each block:
3F = 9.2" = 233mm
2F = 11.4" = 289mm
I also noted that I have to use the 2F lifters, side cover, and maybe a water pump. }
I will keep updating this post as I find new data / info.
Take the info here with a grain of salt untill I can get the details sorted out.
Brian (meigsrock)
Helpful or confusing links, you decide.
http://www.geocities.com/motorcity/pit/9975/dataBySubject/GasolineEngines.html#F-series
http://www.off-road.com/tlc/faq/engine.html#HD_NM_17
http://www.golenengineservice.com/html/calculators.html
PS. If you own a Chilton's Toyota Trucks 1970-88 I do not think that the Engine and Engine Overhaul General Engine Specification on P.3-24 are accurate. (IMOP)
