3d Printed Bushings (1 Viewer)
Outsane
Supporting Vendor
San Mateo, CA
Website
solvefunction.com
I have been pushing the limits with what I can do with my printer.
First I made some sway bar end bushings when whiteline couldn't find a replacement to sell me. Material is tpu and has a hardness of 95a, which is close to polyurethane that energy suspension uses.
Now upper rear links.
I have had the black one in for about 8k miles.
Here it is out for inspection
Going to replace all of them with printed bushings now.
I may try the rear lowers, but I know they are made to flex and twist.
Neat idea. I'm not generally a fan of poly/non-compliant suspension bushings for a few reasons, but it's hard to argue with home made and functional parts.
too cool man, 3d print for the win . i assume 100 infill.
so if you had to replace one of these at 15k miles how long would it take now that the bolts have been broken loose.
Always interesting to see tech advancements that can serve the function of replacing wearable parts, even those that are NLA. Nice work!
damm dude you gave me some awesome ideas, omg like bushing for links that i put across the engine bay for instance. omg thank you holly chit..... eye opening idea right there.
It's pretty much all perimeters, so the lines are all circles.
Maybe 15 min to replace, the bolts are easy to get to and the bushings press in. I am using the centers from the oem bushings.
I put the centers in a chaffing dish with gasoline to remove the rubber.
I think these are still available for the 80 series from Toyota.
But that's not as much fun
and you have been driving for 11k miles so far and now worries, even if it was a yearly replacement it would be easy freaking day wicked cool idea bud....... again thanks
Yeah still available. For now.
Good to know there will be options out there to keep them (and stuff like them) available though. Manufacturers give up on stuff like this when the setup costs for production outweigh the expected sales. With 3D printing the set up costs are low so small volumes can make sense for parts like this.
Was it any harder to install? Thinking less compliant bushings can't tolerate radial misalignment.
Edit: I see you said they went right in, awesome
I made it a press fit by design fir the gray set, so I used my vise to assemble.
Next iteration of things you should probably not do...
These are the rear lower links...
These were welded up since I have bent a couple of sets. I welded on the fzj80 versions since the ends are plain steel. FJ80 ones are cast.
At 325k total for the first set if printed bushings.
I wholly agree with the printed approach for parts seeing axial loads. If you're using the arms in a manner that suggests reinforcement is needed, it tells me you're flexing the axle out, and flexing makes for some big time torsional loads. I expect the bushings will crack up in relatively short order. But, given the cost, maybe you're ok with that shortened service interval.
