To adapt the t-case to the transmission I am using a combination of advance adapters products and custom adapter plates.
Starting at the back of the transfer case I am using the AA adapter plates for a 4L80 which adapt the split case to a 6 bolt round pattern:
GM 4L80E 4 speed automatic transmission to the August 1980-1990 Land Cruiser 19 spline transfer case,adapter kit.
www.advanceadapters.com
Specifically these two items from the kit
awaiting content generation
Advance Adapters 4L80E to Toyota 19 Spline Transmission Adapter ensures seamless compatibility and reliable performance for your vehicle. Easily connect your 4L80E transmission to Toyota 19 spline setups with this durable, precision-engineered adapter designed for a perfect fit and long-lasting...
For the transmission side I am having custom adapters cut from 6061 aluminum, I measured out the bolt holes and drew these up in cad:
This bolts to the back of the transmission, I’ll get it cut from 3/8 which is the thickness of the raised circle around the output shaft:
The next adapter will be cut from 3/4, this adapts the transmission pattern to the 6 bolt round pattern and has provisions for 7 and 14 degree clocking which should get the split case even with my frame rail. The holes will be threaded for m10x1.5 studs.
The next adapter is just to make up whatever is left in thickness, still tbd
I had the first adapter test cut out of 1/8 steel and I need to adjust two holes slightly. I also don’t like how close the clocking holes are to each other so I’m going to add a couple dowel pins to the assembly.
