2H tach sensor wiring - need pics of how it should look like (1 Viewer)
Cape Town, South Africa
hi there. My tachometer (on 1983 HJ47 troopie - 2H engine) was working fine until the workshop pulled the transmission to change the clutch. Sensor got bashed when putting it back and the tachometer stopped working. I took a look at the sensor and noticed that there is only 1 wire coming out, whereas there are 2 connections on the harness. Could anyone post closeup pictures of the sensor (bellhouse side) so that I can see if I can repair the sensor instead of forking out 250 USD for it? TIA
Here’s what I have. I hope it helps. If these don’t work let me know and I’ll try to get better pictures.
1923006
1923007
1923008
1923009
1923010
Hi Michael. Thanks. Read theough your rebuild thread. Impressive! I know it’s a long shot but is there any chance that you may have a closeup of the sensor (where the wires are attached)? I need to figure out if I can repair the original one. Thanks
So in the end I took a dremel and carefully removed enough of the resin to solder on a new wire to the little bit that was previously covered in resin. Covered it all up with hot melt and reconnected. Presto! Wasn't ready to pay 250 USD for a new one.
