Hj47 2H Diaphragm Replacement
Hello all,
Replacing the Diaphragm on the injector pump on a 1982 2H.
Was able to remove the cover, split pin, washer and with a lot of trouble the old diaphragm.
It did no matter what angle I used, the diaphragm fouled on the side of the pump essentially left with one option - bend the front and slide off the rod.
now putting the new one on, it is appearing impossible.
Is there a way to position the shaft so it protrudes out further ?
might get more responses here in the diesel section:
