2H swap into bj40 questions (2 Viewers)
not a simple swap and most likely not worth it. too many differences between a B and an H engine family
is it a 3B, it would have been a B engine originally
have you tried getting it to run?
Worth having a crack at getting that 3B running.. such a great little engine!
There's a good chance the fuel rack is gummed up after that long.. I would definitely pull off the side inspection plate of the injection pump and manually move the fuel control lever back and forth (remove EDIC rod first).. should look like this (from a 2H)..
