- Joined
- Apr 26, 2015
- Threads
- 5
- Messages
- 24
So my truck ('89 60 series with a 2H engine) was running great 6 months before I put it in to storage. I dropped the old oil at this point. Fast forward to a few days ago when I refilled the oil and changed the oil filter in order to fire it up again ready for driving. I cranked it over a few times with the glow plugs disconnected to generate oil pressure before firing it up because I figured if it had sat for 6 months with no oil in the sump it might need some lubrication, figured it couldn't hurt. Then I hooked it all up, cranked and started perfectly but no oil pressure was generated either on the dash gauge or my auxiliary oil gauge (know the dash gauges are kinda iffy). After about 5-10 seconds the EDIC must have flipped it off after not detecting pressure.
Great, now what? The only things I did while it was in storage was work to the turbo (it's an aftermarket Australian turbo 2H), I also replaced the turbo oil hose. No work to the engine was done, nothing that I can think would have disrupted the oil system. Anyway, I know the 2H has an oil relief valve just after(?) the oil pump, I pulled it out and it was all clean, no snagging. I cranked the engine over without it installed figuring that if the pump was pumping then it would pump some oil out of the hole where the relief valve goes. No oil, nothing. I overfilled the sump a little bit to ensure the strainer was in clean oil. I also tried pumping a little bit of oil in the the hole where the oil relief valve goes with the hope that the oil would flow back to the pump and prime it because I know the pumps can have issues with priming. This didn't seem to work and oil just ended up creeping out of my oil filter seal (i guess the oil went the other way up the pipe towards the filter since it may have filled the pump?).
After none of this worked I dropped the new oil and pan and checked the pickup sieve. Everything looked great, absolutely nothing in the oil, only a tiny bit of sludge (less than my VW 1.8 petrol). What on earth could this be? Since I am getting absolutely no oil pressure, I am assuming the pump just isn't pumping, or there is a block between the oil relief valve and the pump. If the pump isn't pumping I'm assuming it isn't priming, or it just needs more time to get the fresh new oil up the sieve and into circulation after sitting for 6 months. I'm scared to try running the truck again if it isn't getting oil, I don't want anything to break
. Anyone have any suggestions or ideas?
Thanks heaps!
Thanks heaps!
