Hi all,
Recently fixed a coolant leak from a lower hose after the clamp hadn't been tightened enough. Did not top up coolant as it was running well and not overheating. Took it on a short drive and immediately started to run hot, switched it off immediately and let it cool down before driving home. Quite obviously hadn't been bled properly.
Now when I drive it, the temp gauge goes up and down slightly, between the mid-line and slightly above the mid-line. I filled the reservoir the other day as well when the engine was cold. No issues when I drove it again, but still gauge goes up and down slightly. I took the reservoir cap off yesterday when engine was cold for a day, and I heard a gurgle come from the radiator. I realise I had also over-filled the reservoir tank.
Does anyone know what's happening here? Was this just air that hadn't been bled properly, and couldn't work itself out due to an overfull reservoir? Am I looking at a head gasket? Coolant and oil are both clean. Not sure what's happening but is freaking me out.
