dropping in a 1fz/a442 not to mention a ton more reliability.
Yes their are 2 or 3 different kits available for tbi. If your going to stick toyota, go with the 2fe equipped with a delta cam grind, no sense doing a normal 3fe. Not that much more work to go 2fe.This APPEARS to be a complete TBI solution:
TOYOTA Complete TBI System
although I THINK i'd be most inclined to stuck with the 3FE swap or a 2FE conversion....
...I used a 3FE valve grind gasket set from Toyota to mate the head to the motor. Jim C. rebuilt the 3FE head for me with Chevy valves (pics are floating around MUD comparing it to a 2F head)....
Nick
Actual installation labor is less installing tbi. Its like bolting on a different carbuerator, coil, and distributor. The rest is running some wires.LOL... love that sticker!!!!
I completely forgot about the AFI guys. I do remember looking at them at one point. But would you be gaining anything through TBI vs. going with the 3FE head? At most I would think simplicity of install due to the fact that the engine is remaining stock and the TBI is an add-on. But at the cost of $1k then you are looking at close to what you would be spending on a 3FE or 2F-E swap (minus fuel tank of course).
What is a "3FE valve grind gasket set"?
This is really a case of time vs money... if one believes the end result of 2FE is about equal to a bolt-on TBI.
$1400 for a full TBI set-up vs $500 for the 3FE components + $? extras for the gaskets etc + more labor
