- Joined
- Jul 22, 2012
- Threads
- 641
- Messages
- 17,894
- Location
- Winter Park, Florida
- Website
- www.cruisermatts.com
Well don’t be upset when you turn a piston into dust
You want the octane boost added to your pump gasoline to keep from pre-igniting the fuel and destroying your engine if you aren't using modern tech to control timing, fuel, boost. Its a safety measure for boosted engines or engines with high compression that aren't tuned for the higher octane fuels. All of my friends with sand rails running boosted engines that are tuned on 91 octane run it to help keep things living longer. Matt is a good resource regarding boosted engines....I don't think that meets the previously mentioned personal goals.
Thanks for the positive reinforcment. I really appreciate the encouragement.Well don’t be upset when you turn a piston into dust![]()
I appreciate that explanation.You want the octane boost added to your pump gasoline to keep from pre-igniting the fuel and destroying your engine if you aren't using modern tech to control timing, fuel, boost. Its a safety measure for boosted engines or engines with high compression that aren't tuned for the higher octane fuels. All of my friends with sand rails running boosted engines that are tuned on 91 octane run it to help keep things living longer. Matt is a good resource regarding boosted engines....
edit to add. Propane was commonly used with older turbo systems because it has a much higher octane rating than readily available pump gasoline, and is much much cheaper and more readily available than high octane gasoline fuels.
Thanks for the positive reinforcment. I really appreciate the encouragement.![]()
That's more like it.
