2F turbo
Depends on what turbo you want to run.
T3/T4 would just be a T4 flange, a T3/T4 has a T4 turbine and T3 compressor.
using a turbo with internal wastegate makes the adapter heaps easier just 2 steel plates and a short length of 2.5-3" pipe
did anyone end up doing a autocad or any other format layout of the flange ??
No solidworks or cad layout of the adapter was made unfortunately.
You know your right about that one.... It's just making the flange for the toyota manifold that will be a pita
The only issue I can think of with an internal wastegate is the room available. Fitment might be an issue
Internal waste gates from what I can remember are completely clockable so you can mount them away from the engine block.
When I did the math on the cfm output on the 2f engine and using that on the charts, the t3 60 came up as the best option for what we try to do and rpm range. You would have full boost around 2000 rpms or so.
and steering??? ;)
yep the rear housing can be positioned whereever you want it aslong as you rotate the center section so the oil line enteres directly ontop and exits directly the bottom
the turbo i run is internal gate and works great however my cruiser is rhd so gives more room on that side of the bay
ive got a contact that could laser cut the flanges for around $10-15$au each
I got a guy at a machine shop that i went to school with who says if i bring him a template he can make the flange that bolts up to the toyota exhaust manifold. Then i would build the rest. Anyone actually have any interest in this???
I'm going to order the turbo flange and go buy the tubing.
It RUUUUUNNNNNNSSSSSSS!!!!!!
:bounce: :bounce2: :bounce: :bounce2:
I'll be gone most of this week to Reno.
But I'll be back this weekend to install the seats in it and drain the water out of the tires...
Is this the adaptor you were kinda looking for at one time.
That is very similar to it Dan, but that is not a 2F that it is bolted to ;)
It was a custom made adapter that I have.
lol..
I'll see what I can do, I need a new intake filter for it, so Bling Chrome Type R air filter it is :)
