2F serial number info... (1 Viewer)
Poser
Oh...Durka Durka Durka.
Supporting Vendor
MN
If you have an original 2F in your 40 or 55, please post up your engine serial number, and the month/year of your truck build and the vin if you would. I am trying to complie 2F year data.
I will be posting this up in the 60 section as well.
Thank you for your help! :beer:
-Steve
12-78 2F 333422 FJ40-296348
early 85 2F 860452
Here's min, Steve. According to Jim C it was cast on 12-18 of '76. If'n you want the serial # you can have that, too. Here it is: 2F 138687
Ed
Uh Oh, I fawked up....not an orginal motor. Well, original, but not to my truck.
Sorry
The engine serial number is stamped into the block on a little flat area right by the starter motor.... :)
Info request...
2/79 FJ40 USA
Engine #2F347599
Frame #FJ40307805
My 2F is a '79 and up, but it has no serial number on the block. It hasn't been ground off, like a midnight auto parts job. Never been stamped with a serial. What's up with that? Replacement engine?
Anyone else?
October '76 FJ40
2F119577 Engine Serial Number
60930 Engine Casting Date (9/30/76)
61031 Head Casting Date (10/31/76)
FJ40233589 VIN and Frame Number
I would be surprised if the engine's been switched, but I don't know for certain.
Yes, a service replacement block.
Lucky dog, you got a brand new engine from Toyota somewhere along the line.
THANK YOU FOLKS!!!
Anyone else?
Poser,
The engine date is cast on the driver's side of the block. See Degnol's post for a pic and de-coding. With Toyota's JIT production, the engine cast date (and carb date, t-case date, and R&P date...) never varies by more than a few days from vehicle build date.
The date is also cast on top of the cylinder head, easier to see on a fully dressed engine. But heads can be swapped from engine to engine, so...
12/76 Date on the vin plate
Block# 2F 138579
Frame # 239609
I don't think the engine has been swapped, but can't be 100% sure.
OK, somebody out there has to have something close to this. I'm told it's a 1981, 2F 528558. Does that look about right, I couldn't find anything close in the post or on the SOR site.
