2F serial number info...
The engine serial number is stamped into the block on a little flat area right by the starter motor.... :)
Look here. :hhmm:
1979 fj40 - help with engine number reference
Greetings all - just bought a fj40 - 79. Brand new to fj world so please bear with my inexperience. What i need help with is understanding if the engine is original to the frame??
Frame #299016 - which according to charts i've seen, i believe puts me in the 1st month of production. The 2F engine charts seem to stop in 1978?? Because i'm new to this...not sure what that engine number should tell me? The frame and engine #'s...are they supposed to match in any way?
thx for any insight from the experts out there.
No, that's kinda the point of this thread - to see where engine numbers fall relative to frame numbers. What's your engine number?
If you refer to this post yours should fall in the 300,000 to 400,000 range:
https://forum.ih8mud.com/showpost.php?p=1498580&postcount=68
Just found this site. Can't beleive it. I've been hiding in my FJ40 for tpp long.
Frame = March 1973 FJ40 144776. Not sure where to find the 2F Engine Number / but I did spot what looked like 30304 stamped on the block on the drivers side. CORRECTION, I have a F155 engine - not a 2F. I know this car inside and out. My father purchased this FJ40 in July of 1973 from the first owner. This was the first car I learned how to dirve. I drove it all through High School and College. I had it redone 10 years ago and it hasn't seen the rain since. :-) It has 109,000 org miles. This is really like a one owner FH40! Glad I found this site! Looking forward to reading and posting often. Will add a pic soon. Cheers!
Ok - got some numbers. So, I feel like the frame and engine are original to each other... So - 1979 fj 40 frame # 299016 and the 2f engine # 11411 61013
Thx
Jason
Thx
Jason
That 2F engine number is the part number of the engine casting. The engine serial number is stamped on the passenger side of the block right by the starter motor.
3 times a charm - thats for your patience. So for my 79 fj40 - frame number 299016 and engine number 2F 343599.
Again, i feel like the engine is original to the frame but i'm curious if these numbers look like they're similar to other 79's?
Experts?...what do you think?
If you read my post from above (copied and pasted below) I think you'll find that it probably is original to the frame...according to SOR.com 2F 332845 was a 12/78 build...add just shy of 10,000 units/month and you get a 1/79 or 2/79 build date of your truck.
http://www.sor.com/sor/fengine.tam
1982 Fj40
Engine # F2 609182
Frame # FJ40-352806
Production date Jan. 82
Vin # JT3FJ40C4C3352806
If I read the charts correct, looks like the Engine is original:clap:
sorry for the late reply.:confused:
can someone please tell me the year of my 2f motor.
serial # 2f-354019
frame# fj40129814
thank you. just got the project cant find any info on the net. only shows me 75 and up.
serial # 2f-354019
frame# fj40129814
thank you. just got the project cant find any info on the net. only shows me 75 and up. THE PINK SLIP SAYS 1972 TOYOTA. trying to match it all up.
serial # 2f-354019
frame# fj40129814
Check out Post #68 <--- THIS IS A LINK
