2F Exhaust manifold: Bolt Size & Thread Pitch? (1 Viewer)
NC
Does anyone know what the bolt size and thread pitch for linking the factory 2F exhaust manifold to the initial exhaust line flange? If anyone has the Toyota Part#, please share! Thanks!!
Not too sure, I picked up some M10x1.25mm and they were not the correct fit, I am assuming the M8x1.25s will do the trick. Thanks for the insight!
is this what you might be looking for ?
BOLTS are NOT used there by TOYOTA .......fyi
@ToyotaMatt - you're on the money, thanks for the link!
Are these studs longer than the original OEM studs? Thanks!
YES ,
both with the additional male threads of 21mm /
and the extra hex-lobular hand drive area no threads
this allows for a nice line-up and up-set of the down pipe flange
these are the best DAM Toyota oem M8 exhaust studs ever produces , and the matching correct new modern 2023 flange / anti-come loose nuts are A+ bench mark TOUOTA still in use today ....
thanks for asking this , i need to take a side by photo ,
also
these are perfect for the far end one 2F
you hang manifolds on the ctr ones
then TORX hand drive these after the fact , EAZY PEEZY step by FSM steps .../
