sark
42601-60262-03
Cross-posting from my thread for feedback. As someone who has never torn an engine down like this, I’m looking for advice on how to proceed. If there’s no flags raised by the condition of the block, I’ll continue to clean and put it back together.
My 60 sat for years abandoned and had obvious amounts of water in the oil, even after changing it out a couple times. Ran ok, but wouldn’t hold an idle. Had some sort of vacuum leak and gasket leak. My plan so far has been to tear the engine down to clean everything and if it looked good enough, to put it back together with new gaskets. Really like some feedback on this 2F block as to how bad it looks compared to other projects, and how to proceed with cleaning it. I can’t find any signs of cracking or catastrophic damage other than the gasket/water in the oil issues. Any feedback appreciated.
“First idea was the intake manifold gasket and the head gasket. I got the 2F stripped down to here as of today. I'd like some opinions on how to proceed. The block looks alright, minus the debris. I wanted to get the top end off to check to see if the block was cracked, but I don't see anything majorly wrong it. Ideally, I'd like to clean everything up and put it back together and drive it. Whether or not this 2F is worth putting back together is where I'm at. If I was all alone in this, I would proceed and put it back together with the gasket set I already have.
Cylinders 1-2
Cylinders 3-4
Cylinders 5-6
Any suggestions? What should I use to clean this thing up? I'm guessing soap and water is not the correct method... Anyone have a detailed 2F rebuild thread to point me towards? I've got the manual but it's not the best on the details for someone who has never done anything like this before.”
Cylinders 1-2
Cylinders 3-4
Cylinders 5-6
