24Volt winch in a 12Volt Truck
Discussion in 'HardCore Corner' started by 4Hummer, Nov 15, 2005.
  1. 4Hummer
    4Hummer
    40
    May 3, 2005
    CANADA
    Friend of mine just scored himslef a free 10000 lbs Ramsey. Dude he got it from said it he couldn't get it to work. After testing the winch (Solonoids, motor etc) we found out that this Winch is a 24Volt unit. We hooked it up to the Skid Loader in the back and sure enough it worked like a champ. (What a bumbass... But perfect for my buddy)
    Now my question is on how to get this bugger to work in his truck.
    The winch is going to be reciever mounted, so we are going to wire quick connects front and rear, we will be installing 2 batteries in a custom tray in the rear of the bed.
    What I need help with is A: How to wire the Batteries for 24Volt (ie: Parallel? series? etc) and what sort of switching device (Isolater etc) to put in between the primary battery and the 2 batts in the rear, to charge em?
    Heres a cheese ass pic I put together.
    [​IMG]
  2. FJ40_owner
    FJ40_owner
    815
    3
    Aug 16, 2005
    El Dorado County CA
    You need to wire the batteries in series.
    You need to figure a way to charge the batteries. The winch will rapidly discharge the batteries.
    You need to figure a way to prevent anyone from connecting a 12 volt device to the circuit.
    In my opinion the setup is not worth the effort.
    My .02
    Good luck
    JB
  3. rusty_tlc
    rusty_tlc Dain Bramaged Member
    13,464
    Media:
    3
    Albums:
    2
    968
    Jun 23, 2005
    Reno, NV
    The first thought that comes to mind is to use relays to change the hook up.
    USe series for winching and parrallel for charging. Use a standard RV isolation set up for the charging circuit. I'll try to post a schmatic later.
  4. 4Hummer
    4Hummer
    40
    May 3, 2005
    CANADA
    The two batteries will be inside a custom box in the rear of the bed. and will not be on any other circuit other than the quick connects for the winch.
    Problem will be charging these two batteries that will be wired in series.
  5. lowenbrau
    lowenbrau SILVER Star
    3,698
    130
    Jan 22, 2003
    near Calgary AB
    Do a search for series/parellel switches. That's what you need.
  6. honk
    honk
    3,413
    Media:
    10
    372
    Nov 14, 2004
    PNW
    No swapping for a 12 volt motor I guess?
    If it were an 8274 I'd maybe trade a 12 volt motor for the 24 volt motor, but Ramsey motor probly a no go.
  7. 4Hummer
    4Hummer
    40
    May 3, 2005
    CANADA
    I searched "No matches found"
  8. rusty_tlc
    13,464
    Media:
    3
    Albums:
    2
    968
    Jun 23, 2005
    Reno, NV
    I had a schmatic drawn up but it was illegable by the time I resized it, I can e-mail it to you if you like.
    I thought of a better way to solve the problem anyway. Just have the motor re-wound for 12V by an electric motor shop.
  9. rusty_tlc
    13,464
    Media:
    3
    Albums:
    2
    968
    Jun 23, 2005
    Reno, NV
    This is how it could be done. Disclaimer, if you choose to use a schematic posted to a forum by persons unknown to you without doing the proper research on your own you get to fix any problems that come from using it. :doh:
  10. import silvia
    import silvia
    471
    3
    Feb 14, 2005
    Tucson
    I would put a fuse on the pos terminal of the switched battery. And look to find a high current switch that can make all of the throws at the same time (I'm thinking big rotary switch).
  11. rusty_tlc
    13,464
    Media:
    3
    Albums:
    2
    968
    Jun 23, 2005
    Reno, NV
    One low voltage switch and two DPDT relays rated for the correct amprage. No fuse, a thermal re-settable breaker. I didn't include those details, or a bunch of others, like the correct wire guages, hence the disclaimer.;)
  12. fng55
    fng55
    133
    Sep 16, 2005
    on my old ramsey 7905 you can change from 24v to 12v by changeing the soleniods, same motor for both voltages. can the new ones do the same thing?
    carl
  13. HI^C
    HI^C
    1,234
    2
    May 22, 2003
    $$$$ for these items i imagine will put this way out of reach, your talking min 200 amp rating on most of this stuff, IMO.
    make the call to ramsey to figure it out (motor or relays, etc...) , or post it on military boards and hummer boards unload it and buy a 12v winch.
  14. rusty_tlc
    13,464
    Media:
    3
    Albums:
    2
    968
    Jun 23, 2005
    Reno, NV
    Ramsey specs 160A for their 12000/24V unit with a 10000 load so 200A would be correct. (The same unit in 12V requires 335A with the same load.) Also consider the expense of two batteries.
    I agree with HI^C Ebay the 24V unit and buy a 12V unit with the money.
  15. 4Hummer
    4Hummer
    40
    May 3, 2005
    CANADA
    So his options so far seem to be:
    1: Replace the 24V motor with a 12V motor and be done with it.
    (best option)
    2: Sell Winch
    3: Intall 2 batteries in the back in series and run them off a seperate 24V alternator
    4: Install 2 Batteries and do some crazy ass wiring and hopefully not start an electrical fire.
    What about running a 12V to 24V inverter to charge the batteries ? or will the draw be to much while running the winch ?
  16. HI^C
    HI^C
    1,234
    2
    May 22, 2003
    pretty much,
    think it will be a $$$$ versus time and hassel
    CONTACT ramsey first,
    if your going to have more $$$ then it would be to have the 12v winch, why even play with the 24v
  17. cruiserrg
    cruiserrg
    306
    Feb 11, 2002
    Mankato, MN
    You could do some research on Military CUCV. My M1008 had a 24 system for only starting, the rest of the system was 12 volts. 2 batteries and 2 alternators. I converted mine to all 12 volt so I am kinda familar with the system. Basically the alternators had isolated gnds and were wired in a way to charge the system 24 volts. CUCV alternators shouldn't be too hard to find, and wiringing isn't too bad.
  18. haffi
    haffi
    530
    18
    Aug 14, 2005
    Iceland
    12v or 24v
    Some Unimogs have 24v starter, 2 batteries, one 12v alternator and some switch-unit to change the battery connections from paralell to series while starting. Some 80 series tlc have the same mechanism but i guess the switch is smaller and will not handle the high amps as well.
    You might consult some unimog fans and see if they know this system, i am not sure if this switch-thing will handle the winch for a long time. Ask some Mercedes geeks ;)
  19. CruisinGA
    CruisinGA
    6,168
    16
    Mar 27, 2003
    Georgia Tech
    pretty easy to do.
    use a battery isolator to charge two 12v batteries at once.
    Have them connected in series to give 24v only to the winch.
    There you go.
  20. rusty_tlc
    13,464
    Media:
    3
    Albums:
    2
    968
    Jun 23, 2005
    Reno, NV
    So how exactly would you hook that up?
