Hey, all - new user here, and proud owner of a new-to-me '22 GX460! I've lurked the forums for the last six or so months, and I know answers are scattered around for some of these questions, but haven't seen much for my specific case. My apologies in advance if I'm doubling effort on some of this data - I've used the search function a lot recently, but any links to forums that address some of this are greatly appreciated!
Bottom line upfront: I'm a reasonably mechanically inclined individual, and need help planning the right modifications to my truck to make a drive from the lower 48 to Anchorage both safe and enjoyable. By "reasonably mechanically inclined," I mean I'm willing to turn a wrench on most of this truck unless it involves disassembling the drive line. I'll leave that one to the pros.
The truck: '22 GX460 Blackline, 81,000 mi with no aftermarket additions (yet). Maintenance history is good, but no transmission or coolant change during its life, both of which I know can be controversial topics.
The use: bought this truck to drive from Virginia to Anchorage, AK (work will be moving me there in August/September) with a camper in tow and about 1,500 lb of household goods. I plan to make a road trip of it. My research journey has already started with Mileposts and lurking the ALCAN Facebook page.
I'm planning some maintenance and add-ons to my GX in prep for this drive, with the list below. The big things I'm looking for:
- Recommendations for tried-and-true parts for each application
- Any gaps in the plan
- Any unnecessary parts of the plan I could trim out
Here's what I plan to do:
1. Total fluid change. Oil, transmission, coolant, and diffs.
I've never changed the oil on a GX, though I've done it about a thousand times on my old Camry. Should I go 5W20 in anticipation for cold conditions, or is 0W20 good enough?
2. Trailer hitch add. What are my best options for a 6,500 capacity hitch? Should I include a weight distribution kit as well?
3. Tires. I know there are a thousand opinions on this. Should I be looking at full-on studded snow tires for the entire drive, or are there less aggressive tires I could safely use? If so, should are we recommending chains? Plastic? Steel?
4. External storage. Primarily to carry 2 fuel cans (not bought yet - recommendations?) for the inevitable several-hundred mile stretches of no gas stations driving a thirsty V8. Are there any low-profile roof rack solutions that won't break the bank?
5. Transmission cooler. I've seen a lot of advice out there about adding a transmission cooler when towing, especially when mountain/non-level terrain will be a factor. Where should I be looking for this? How aggressive of a cooler should I be looking for?
6. Frame protection. My frame is in good shape. I'd like to keep it that way. What products are y'all using in wintry climates to undercoat? Would you recommend doing this yourself, or paying someone else?
7. Body protection. Some portions of this drive are going to be on under-improved roads, and I'd like to keep my paint as unmarred as reasonably possible by stray rocks and flying ice chunks. What's a good way to do this without breaking the bank on full-body PPF?
Thanks in advance for the help and advice, and once again, I apologize if I'm soliciting a lot of advice that people are tired of sharing over and over again.
- Chapo19
- Chapo19
