2010-2013 GX front bumper options?
Poulsbo, WA
If you have Parking Assist, be sure that there are holes for the parking sensors in the front and also for the rear if you go with a rear bumper. There should be 4 holes for each, front and rear. 1 at each corner and 2 facing forward. My Metal Tech front and rear had them and I can still use my Parking Assist.
I have dobinson front and rear...had to drill holes for front (rear had them) but Parking assist working without issues.
  • Like
Reactions: r2m
I assume you carefully located them as close to the stock locations as possible?
Did you have any issues with rotational orientation? Meaning that keeping the 12 o-clock position from your stock bumper would still be the same 12 o-clock position on your Dobinson.
To be honest, I had the shop do them (and Dobinson sent a template for where they should go). And no issues.
Good point, unfortunately, I haven't seen any that support the headlight sprayers.
I've been thinking about getting back my headlight washers again. Need to see where to cut holes and what the nozzle looks like. I hope the guys who put my bumper on didn't just cut it all off! :oops:
I too thought they were always a gimmick. Thanks for info! Albeit, mine went away with my from bumper.
So I finally picked a company (Trail Ready) for a front bumper and they were able to slightly alter their original configuration to accommodate, and retained all the options I wanted.
  • Retain headlight sprayers (because the location of the cut stock bumper retained them)
  • Retain parking sensors (this is change from their original configuration and I supplied aftermarket flat sensor bezels)
  • Use of aluminum for rust resistance, and potentially lighter weight. (Winch cradle and hoops are steel, main bumper body is aluminum.
  • Hoop design for protection
I went with the Trail Ready bumper for the above reasons AND because I was able to go to their location and work with them. (They took measurements for the park sensor locations, and verified the headlight sprayers would work without modification).
I had them perform the install, which did require adding some wire to the park sensors at the corners.
I will say the process had very few hiccups, but all worked out in the end. I’m very happy with the end result:
That is absolutely awesome!
For me, your bumper looks like it checked everything I would have wanted, especially the lighter weight material. Too bad I already have my MetalTech...
Couple of questions:
1) How did they attach the bull bars to the bumper? You cannot weld aluminum to any type of steel.
2) Do you know how much this new aluminum design weights?
The tube guard (steel) is actually bolted through the aluminum main bumper body with some rather large bolts. With the threaded part inside of the tube. The aluminum bumper (I’ll have to check thickness) is then bolted to the winch cradle (which is steel). All bolts are carriage bolts that go thru square/rectangle holes and are captured by large lock washers and nuts. This allows for adjustment which can be a pain, but also a blessing to align at the same time.
Edit:
[All plate (Aluminum and steel) is 1/4” (.27” with powder coat). Even the top winch cover door.]
As far as weight savings, I don’t think there is much compared to the Ironman or ARB.. as they said it’s about 135lb. (I personally didn’t measure) with the tube. I guess the nice thing is one could order this bumper without the tube. Currently I have stock suspension, and I think I lost about 1/2”clearance measuring wheel center to fender edge.
I can take more specific images if anyone is curious about something.
One thing I learned is that 18” PIAA light bar (which is what the center bar is designed for) has 2 generations of the same light bar. The 1st gen one doesn’t have side mounts, which the 2nd gen (although same model#) has, which would have made the light look very integrated into the bar. I’m ok with the 1st gen light as it was $300 cheaper and it sticks up a tiny bit over the hood line, so I can actually see the center bar and judge distance better. So it works for me, even if I had to drill 2 holes through the flat plate.
I agree with having the light bar a wee bit higher as "reference" point for the end of the bumper. It'll probably save a lot of minor dings on rear bumpers when parallel parking! :p
Link for the C4 bumper goes to 404 Not Found. :( But I found this image of a 2010-13 GX460 on their front skid plate page.
Is this the C4 Front Bumper that was being referenced? --I've seen another bumper they made and it was more of a hybrid and looked nothing like this one.
If not, anybody know who makes this bumper? I like the lines of it way better than anything else available for these trucks.
Only C4 in the past I am aware of..but looking at cutouts..looks to be another prototype or one-off
gx_460_assassin_hybrid_tube_winch_bumper_c4_fabrication_10_jpeg_d5539c4df2483b1c26ff48b8b0f6a360a7b2bd1e.jpg
A 2020 prototype that I don’t think was ever sold
Looks similar to the Victory Strike, which is available in aluminum (for the OP, 3 years later).
Yep. You're right. Cutouts look very similar.
Also, now that I am zooming up real close on the light bar cut out, right in the center of it is the C4 logo. You can see it much better in the second bumper pic in your post which is when i first saw it. And then i looked back at the one I posted and the C4 logo is def present on that one as well. Def a C4 bumper.
Darn. I wonder if they could be convinced to make one...
Agreed. I've been eyeing that one as well. I'm a full bullbar type of guy, but I don't like the hoop/bar design on the Victory. I prefer the style of the C4 hoop/bar design.
But, I do really like the lines and design of the main bumper section of the Victory. It's prob what I'll be getting since this C4 is NLA.
Yeah, I went back and forth on the bars but ultimately didn't get them. They are nice for animal strikes but I like the cleaner look without them. And so far (I'm 63 years old), knocking on wood, I have never hit a deer.
FWIW, I emailed C4 regarding this bumper and I got this below reply from them. It's prob not something I'll be holding my breath for, but sure would be nice if they did offer this as an option in the future.
Thank you for reaching out and always great to hear such enthusiasm about our product! Unfortunately we do not offer that bumper at the moment but, we do have a plan to make and sell that bumper here in the future. We don't have it on our radar as of right now but it is in the works!
  • Sad
Reactions: r2m
