Mine were basically factory-new at ~125k, and I’ve seen others post similar.
The issue seems to be more of a stress riser at the crease than the material being thin. The change in design seems to support this theory, as that crease was changed to a much more gradual curve.To keep track on numbers for our discussion with Toyota here:
Our 2013 developed “the crack”. It was identified yesterday. I changed my 07 Tundra radiator some time back which is a similar unit—but for a different issue (core leak). Frankly at over 14 LCs and 17 Toyota 4WD in my family history, 7 mine, these are the first plastic and non-copper rads I’ve worked with. Not a fan.
However, a few observations.
1) not sure the lightly smeared painting of part info on the flat is anywhere close to a culprit.
2) the underneath really doesn’t appear to look like a thin or weak point at this crease.
3) watch next time u change a belt or wires or plugs where your hand rests to make the reach.
Engine and radiator must be cold before opening the radiator cap. Because you said your over flow reservoir was empty, that means that the crack still has enough of a seal to cause a vacuum to pull the remaining fluid back into the radiator. Use a flashlight and look into the radiator and there should be enough fluid to just cover the core so you can see the amount remaining. If you add water to the radiator, just remember how much. If you have to add more than a couple of cups of water to cover the then someone else needs to do an inspection for a leak lower in the cooling system. You only need to cover the core when the engine is cold.With my reservoir being empty, any issues driving the 20 miles to the shop? I don’t have any coolant on hand to put in.
LC 2015 with 200,000 km
hot weather in Abu Dhabi...looks like it will need replacement soon...keeping it mostly underground parking so hopefully will still do this summer...
Which engine? Most posted here would be the 5.7 but I’m not sure how that could contribute to the problem other than total heat put into the system.
Usually before you have a leak the crack will extend past the square area to the right a little. I’d think you have some time.
I opened mine up and didn’t end up replacing them. As mentioned my originals were perfect, but also the replacements from toyota (part numbers gained from this forum) would have fit but weren’t an exact match and just didn’t seem as high quality as the originals. Material, molding marks, etc. Whatever was on there was working so well I didn’t want to change anything. Fearing the replacements might be more closely related to the 100-series parts that had so many issues I just put it back together with the originals and planned to check them in another 50-75k.
When fully warmed up or with a cold engine?View attachment 2304059
Back from the shop.
Coolant is just above “L” in the reservoir, though. Should I (pick up some and) add more?
