2008-2018 Radiator Failure and Public Service Announcement
2010 LX 570 Failure.
Add another one to the failure. 2009 with 188k miles. Called local dealer and they quoted me $450+ for part or $1k+ for them to take care of it. That doesn’t include me getting it to them, I am 45 minutes away! I got lucky as well and found it before it was catastrophic. Reading this thread convinced me to do it myself. I normally use Toyota parts only, but I have not seen where they have corrected this design flaw. I went on Amazon and found a TYC model 13080 radiator for $70 with prime 2 day shipping! It is supposed to be delivered today. I decided to try the TYC version because I replaced the headlights on a Sequoia that I previously owned and they were identical to the factory version. Even if this model has the same defect at least it’s less costly.
This 100% my personal opinion but I'd trust a Toyota radiator with that known failure mode that is quite easy to monitor/predict FAR more than an aftermarket solution, especially one that is so cheap.
Plus, it looks like Toyota is finally correcting the problem on new ones. No clue how you'd make sure you got the updated part though.
I Just ordered a Nissens radiator. Never put them in anything japanese but used to run them in European cars with success. I'll see what it looks like when its gets here, it was more expensive than the denso but a 100k mile radiator just isn't going to fly.
on
I just finished install and everything went fine. As far as price being so cheap, I still can’t believe it. I went back today and searched same part and it is listed for $192. Radiator looks identical to factory installed version. Will update when something happens.
Pretty good pricing from Toyota South Atlanta on parts (41% off list) + free shipping for Cyber Monday - in case anyone is in need:
Parts $362.68
Shipping $24.95
Coupon $24.95
Tax $0.00
Total $362.68
Shipping Address
State VA
Postal Code 22041
Country USA
Products on Order
Part Status Description Quantity Price
00272SLLC2 Toyota 50/50 Pre-Diluted Super Long Life Antifreeze/Coolant 2 $14.70
1220438010 VALVE SUB-ASSEMBLY, VENTILATION 1 $4.98
1640050384 RADIATOR ASSEMBLY 1 $263.59
1657138080 HOSE, RADIATOR, NO. 1 1 $15.20
1657238131 HOSE, RADIATOR, NO. 2 1 $20.00
90466A0026 CLAMP OR CLIP 3 $6.47
9046707117 CLIP 7 $0.88
9046743002 CLAMP OR CLIP; CLIP 1 $3.94
Parts $362.68
Shipping $24.95
Coupon $24.95
Tax $0.00
Total $362.68
Shipping Address
State VA
Postal Code 22041
Country USA
Products on Order
Good find, please note they don't ship antifreeeze or any chemical.
When replacing the radiator, is there actually a need to drain it while still mounted? I'd like to avoid pulling the skid. Thoughts?
That depends on how much of a mess you're comfortable with. Once the lower radiator hose comes off the motor or the radiator side, it's going to drain whether you're read or not :D
I suppose if you had a reasonable way to catch the fluid that will be pouring out, you could remove the radiator sans skid plate removal. Spend a few minutes with a hose washing down the rest of the residue I suppose. It's going to be easier just to remove the skids imo
Me wondering if there is a link between radiator failures and region the truck resides in. Is it possible these radiators fail more often in hotter climates? Quite a few posts seem to come from owners living in the South.
I think there is direct correlation with southern trucks and radiator failure. My lx 570 had the crack starting when I purchased it. It is 2013 model and had 86000 miles. It was a late model 2013 and put into service in November 2013.
This thread is giving me anxiety. 95k on the clock... just getting into off roading and vehicles in my 30's. Lawd have mercy on me here.
Why? It’s easy to spot the crack and most seem to be drivable for many thousands of miles even with the crack before it actually loses integrity and starts to leak.
My 2013 spent 2 years in Houston and then 2 years in Illinois. The radiator started to crack around 76k.
Anecdotally if you read the forums here failures are all over the map. I don't think it's due to ambient temp, I actually think it's due to heating and cooling cycles, but you'd need a much larger sample size than this thread to confirm
I just had my local Toyota dealer SM do a visual inspection/confirm/record VIN of a hair line crack on the radiator at usual place with 58k miles on my 2011.
