- Location
- United States
Here's the rundown on this car;
I purchased it from my boss (our president) last April after drooling over it for 7 years. He owned it from 2011 and 84000 miles to April 2018 and 145000 miles. He purchased it from the owner of the Lexus dealership in Bernie, as it was the owner's personal car (a friend of his set the two of them up). Previous owner gave me his full stack of service records for all oil changes and alignments. Timing belt was done just after 90k miles, and the heater tee broke at that time (what actually brought him to mechanic). His wife back up the car with door open and bent the door hinges slightly. I purchased the car with the dent/bend/
I enjoy doing maintenance and working on cars / boats, so this has been a real hobby for me - especially the lack of rust on the underside of the car.
From when I purchased it, I have had the brakes turned, new brake pads, all wheel bearings repacked (drive front was replaced with OEM - Timken) and door fixed.
I then flushed the AHC system (felt it was due for a flushing, but the old fluid was good and brown, not milky - was happy about that), and the accumulators seem to be in great shape (going from low to high is smooth and responsive).
I changed the oil program to run the extended Mobil 1 (M1-209) oil filter and Mobil 1 Extended performance oil. This has pushed oil change intervals to 7500 miles (and I check the oil regularly for discoloration, etc.).
Belt tensioner pulley (bearing specifically) began going out on me at 169,000 miles - I replaced with OEM tensioner pulley and belt before it went out completely. Problem was identified as worn bearing in tensioner pulley. Tensioner spring is still in good shape, so no need to replace anytime soon.
Electrically and mechanically everything is sound on this truck and ready to go for a long time. That being said, it is a 2006 with 172,500 miles and there are a couple of minor things I'd like to point out up front.
• Small tear in drivers seat (left side bottom) - small enough to be repaired by leather repair kit
• Front driver and passenger seat leather could use reconditioning
• Subwoofer needs to be re-foamed (kit is $25 and BestBuy car services here off 290 and Tidwell will re-foam the sub for $60 - just haven't done it)
• Windshield washer - hose tee for line to passenger jet broke and replacement part I ordered had oversized clip for hood receptacle. I have the washer line, but need to get the new hose tee ($7 from Toyota parts). Currently isolated to driver jet until I order the replacement tee. 5 min job.
• TPMS sensor out in one of the wheels - haven't taken to discount tire to identify which and replace, but that's $60/sensor. Car still has original TPMS sensors.
• Hood lift actuators - drivers side is going out, hood will close if on downhill or level surface after a minute or two unless blocked. $45 part.
That's it! It's a great car that I don't want to sell, but given I'm on track to put 40,000+ miles on her in the first year it makes sense for me to sell this and move on to something more fuel efficient.
Asking $16,500 - or make me an offer! (No low ballers, have this for sale locally and is generating attention, but wanted to put on IH8MUD due to the amazing technical support provided by this community)
More pics on CL ad: 2006 LX470 - Rust Free - Never Offroaded - 172500mi - Full Maintenance
