its 4 and 12 for the GX470 to do the ZPC.... my port is mounted upside down from this picture as i assume they all are and doing the manual method with the fuses pulled turned all lights off
.A. Clear the zero point calibration data.
(1) Turn the ignition switch off.
(2) Check that the steering wheel is centered.
(3) Check that the shift lever is in P.
(4) Turn the ignition switch to ON.
(5) The ABS warning light and slip indicator light come on for 3 seconds to indicate that the initial check is completed.
(6) Using SST, connect and disconnect terminals 12 (TS) and 4 (CG) of the DLC3 4 times or more within 8 seconds.
(7) Check that the slip indicator light comes on.
This clears the old data points now you are ready to perform the
zero point calibration of the yaw rate and acceleration sensor.
(4) Using SST, connect terminals 12 (TS) and 4 (CG) of the DLC3.... keep them connected during the entire procedure.
(5) Turn the ignition switch to ON.
(6) Keep the vehicle stationary on a level surface for 5 seconds or more.
(7) Check that the slip indicator light comes on for several seconds and then blink in the test mode pattern (0.125 seconds on and 0.125 seconds off).
Dont touch anything...now you have to calibrate the Downhill Assist Control.
(1) Turn the downhill assist control switch on.
(2) check that the downhill assist control indicator light is blinking.
(3) Turn the downhill assist control switch off.
(4) Turn the ignition switch off and disconnect SST from the DLC3.
(5) Drive the vehicle straight ahead at 40 km/h (25 mph) or more for at least 10 seconds.
you are done....the hardest part for me was finding a place where i could do the procedure and then drive straight for 10 seconds above 25mph..... my lights went off after a couple minutes of driving.
