Engine stalls in traffic sometimes turning a corner sometimes pulling up to a stoplight. Always restarts and runs just fine. No check engine light no stored codes. Has 39 pounds of fuel pressure.
I cleaned the throttle body last night. Did it last summer as well. Was not terrible. I also cleaned the Mass Airflow Sensor. I have a Hewitt SAIS bypass installed but I’ve had that for a few yrs now.I agree with Rednexus above. I had a stalling issue that was due to a dirty gummed up throttle body and MAF. You can buy a $15 kit at Walmart that includes spray for MAF and throttle body. Only use MAF cleaner on the MAF! These are very sensitive. Use an old tooth brush for the throttle body. You need to do a throttle relearn procedure once cleaned. Completely fixed my problem
How often are you getting the stalling? I think that a failing PS pulley would eventually cause the serpentine belt to fail, but not stall the engine. I'd still get live data like @Rednexus suggested.I cleaned the throttle body last night. Did it last summer as well. Was not terrible. I also cleaned the Mass Airflow Sensor. I have a Hewitt SAIS bypass installed but I’ve had that for a few yrs now.
I noticed today some bronze/brass shavings around the ID on my PS drive pulley. Both inside and out like a brass bushing is wearing out. Steering is a little noisy and hard I noticed today. Maybe locking up and stalling???
I reached out to Paul today. He suggested I unplug it and return to stock. I have the block off plates installed so not sure about that.Reach out to Hewitt about this. I had the same, and it turns out for a few years they had intermittent issues with wiring harnesses. Have you noticed whether this primarily happens when the car is cold started?
Originally i thought mine was a transmission issue. Cleaned the maf. Repalced the maf. Cleaned the throttle body. Cleaned sparks. Replaced air filter. Only thing that fixed it was replacing the SAIS system with OEM parts.
Did you do the work yourself restoring the original SAIS?Reach out to Hewitt about this. I had the same, and it turns out for a few years they had intermittent issues with wiring harnesses. Have you noticed whether this primarily happens when the car is cold started?
Have you checked the MAF readings while the engine is running? Otherwise, it's premature to think about replacing SAIS parts. A number of us have had similar problems on here due to a bad MAF connector, which is $16 on Amazon. Without checking the connection, you run the risk of replacing parts that aren't bad and having the same problems.Did you do the work yourself restoring the original SAIS?
I checked the MAF readings on mine, and have had the new SAIS kit with no stalls for a year on mine- not sure if you were asking me or him. Agreed- def check MAF numbers firstHave you checked the MAF readings while the engine is running? Otherwise, it's premature to think about replacing SAIS parts. A number of us have had similar problems on here due to a bad MAF connector, which is $16 on Amazon. Without checking the connection, you run the risk of replacing parts that aren't bad and having the same problems.
I need to check those readings. Thx for the advice.I checked the MAF readings on mine, and have had the new SAIS kit with no stalls for a year on mine- not sure if you were asking me or him. Agreed- def check MAF numbers first
Hi, have you fixed this problem yet? May have the exact same problem. It randomly dies and always restarts. Mine also have the Hewitt bypass installed. Would appreciate for more info! Best,Engine stalls in traffic sometimes turning a corner sometimes pulling up to a stoplight. Always restarts and runs just fine. No check engine light no stored codes. Has 39 pounds of fuel pressure.
Plot the MAF readings vs. time using TorquePro or a handheld scanner that can give you graphs of live data/sensor readings vs. time. You should have a smooth plot. If you are getting abnormal blips in your MAF readings that correspond with a stalling/hesitation/surging issue, the issue is likely the MAF or the MAF connector.Hi, have you fixed this problem yet? May have the exact same problem. It randomly dies and always restarts. Mine also have the Hewitt bypass installed. Would appreciate for more info! Best,
Cool! Thank you for the reply! Yeah, when the car is idling, I find that it keeps wanting to rav to above 2000rpm. I will definitely look into that.Plot the MAF readings vs. time using TorquePro or a handheld scanner that can give you graphs of live data/sensor readings vs. time. You should have a smooth plot. If you are getting abnormal blips in your MAF readings that correspond with a stalling/hesitation/surging issue, the issue is likely the MAF or the MAF connector.
Per my previous posts, the MAF connectors on these rigs are fragile; something as innocuous as unplugging the MAF connector to plug in a Hewitt SAIS bypass may be enough to damage the connector and cause all sorts of strange behavior (that will sometimes, but not always, throw a code). Many of us on here have had MAF connector issues, so it's very common, and will become more common the older these rigs get.
This sounds more like a MAF issue to me. I dont understand the technical details of them failure mode of the SAIS bypass kit, but mine seemed to stall out of the bottom end of the rev range after starting the car, driving for a few minutes, then coming to a stop and idling in drive.Cool! Thank you for the reply! Yeah, when the car is idling, I find that it keeps wanting to rav to above 2000rpm. I will definitely look into that.
