200 Series Wheel on 100 Series front hub. V. ModificationThread? (2 Viewers)
So I have some bronze heritage wheels I had purchased. I had gotten confused on the modification needed to fit the front wheels because some mentioned just hitting their front dust cap in with a hammer and it working, but that’s not my issue. I see now that they are referring to the actual bolted on hub cap.
I see there are talks of modifying it, but I cannot find any actual threads on the actual modification. What are people doing? I will go spacer if I need to but would rather not if I can get around it.
Spacers
1 inch will work if the backside of the wheel is not completely flat. 1.25" if you want to make very sure there's no interference.
These are 1 inch spacers - you can see the studs still poke a bit.
I assume the OEM wheels look like this on the backside so the studs poking work fine.
However if it's a hub-centric spacer, you'll still have the center-bore problem with BORA spacers like mine. I don't know if the spidertrax are the same design or not.
What year is your LC?
