Just for more info my 96 model 1HD-FT had the ASCD on it when I bought it.
It does not now.
It does not now.
Do you know how many ks your pump had on it when you noticed this happening @AussieHJCruza?
So I heard my name mentioned about timing, but im no authority. Working from Dougals advice regarding peak cylinder pressures is why I originally retarded my 3B timing and to my surprise I gain significant lower end torque which I really enjoy. Very improved drivability. I think that the rate at which fuel burns can be influenced by so many variables that to advance your timing to the point at which you completely maximise power you take away your margin of safety for hot weather and hot fuel or high intake temps from running no intercooler or perhaps you try out a new fuel additive that happens to have cetane in it which also speeds your burn. Very easy to get into a situation where you are over advanced and don't know it. Your performance suffers, use more fuel, overheat often, but more importantly your engine experiences much greater peak cylinder pressures and eventually you will break a nice big hard to replace piece of it. Namely your crank shaft. How do you know what to set your timing at? This should be a whole other thread or at the very least a huge part of this thread. Power is a lot more to do with timing peak cylinder pressure, more specifically when it peaks in the relation to TDC/ 18 degrees ATDC If I remember correctly, than simply the amount of fuel you inject. I don't know this engine or your pump but a dyno tune to see peak torque is all I can think of. Now that is assuming linear fuel volumes which might not be the case. This is a black art that need to be deciphered Im guessing. Still for me I run retarded....yes go ahead and throw some jokes in there, its ok....I pick up extra low end torque and a better safety margin at the expense of more peak power and better fuel economy. Once you set your timing that not simply it, other forces influence timing on a daily basis. This is where computers are helpful....what on earth did I just say.....barf......they compensate for much of that jazz continually. For us mechanically controlled guys it is a guessing game, make no mistake. A habit I've developed over the years when Im working the engine hard towing or climbing hills in the summer or stuff like that I never lug it and generally run 3-400 rpms over my usual shifting cruise range.
Right. Thanks mate.
I have had my 80 for about 130k, the pump was apparently rebuilt just before I bought it. Since installing on board AFR and EGT, I have noticed I cant keep the AFR constant through the rev range and consequently as the AFR drops, the EGT also rises with the revs.
I'm thinking the advance is not keeping up to the rpms.
Thanks @David60series
@Antony why does the FT pump do this?
Is there a rational behind it?
Can it be "fixed" so this does not happen?
I would like the ability to tune to all rpm.
I have previously tuned to full throttle AFR to be on the safe side but that leaves me VERY unhappy with the lower rpm power, torque and drivavility as you may understand.
I was also under the very vague and uninformed notion that tired springs would cause any counterweights/flywheel to advance earlier rather than later and as such a tired pump can advance a little too early or much on the curve and you get some black smoke.
Right. Thanks mate.
The FT spec motor might have had an improved cam that was efficient in this range? I imagine it breathed better also.
I am probably noticing the curve more in an early combustion chamber type 1HD-T.
If you never measured AFR or even EGT you would probably never know.
