1HD-FTE Conversion - Creating my perfect 80 Series (4 Viewers)
Great Lakes
I’ve had my 80 for about two years, and have had my 100 series for around 5. The 100 got me into Land Cruisers and inspired me to go deeper down this rabbit hole. The 80 is my favorite as far as styling and the hardware below the body, while the 100 is a refined workhorse.
Here is my 80 as it is today with a perfectly running 1FZ-FE, which I will soon turn into a not-running 80, and eventually back into a diesel 80. :beer:
I’d always fancied cars with diesels, always wanted one, but never did nor committed to a single platform enough to consider a swap. Recently after reading threads by @Mag71k5 and @lelandEOD, I thought that this might actually be doable in an 80.
Off to searching I went and Shortly after I found a 1HD-FTE and A750F 5 speed auto powertrain from a 2005 HDJ100 with an alleged ~40k miles. The story I got on this powertrain is that it came from an armored 100 series that was located in Guam and owned by the DoD. I made a deal and headed out to pick it up this last weekend.
I drove home fully stoked with the engine in the back knowing the hardest to acquire part was done.
Likely there won’t be a ton of novel work going on in this thread, but I’ve learned and been inspired a ton from reading about and seeing photos of other’s efforts, so my hope is to provide some of that here.
I got the engine home, and dug right in the next day to learn more about what comes next.
An “undressed” shot after labeling and pulling the harness from the engine.
5 speed on a furniture dolly and a starter in a bucket - you won’t believe this, but after the cost of the engine, the bucket was free.
In my opinion, the most intimidating part. I need to either A, grow the cojones to wire this myself, or B, ask for a custom harness from the folks down under.
Non-EGR variant…cool. And clean. Since this is a non-EGR motor, I’m making the assumption it’s also not VNT - need to check on this when on get back in the garage.
I continued capping off lines and pulled the valve cover to check on the state of things.
Pulled the timing cover to see what was going on:
To my eyes this hardware looks fairly good including the water pump based on the condition of the hub that the fan pulley mounts to.
And now on to what’s next - I’m a bit of a maniac so i figure eliminate the unknown and handle the timing belt once I get the engine in the stand. I also plan to do the thermostat and o-ring, and also do a valve adjustment and replace the valve cover gasket. My thinking is there will be no easier time to wrench on this engine than now. I’m also considering pulling the turbo to check for play, replace studs & nuts, and also install an EGT sensor pre-turbo on the mani.
Still in the phase of acquiring parts and I’ll say some are harder to find than others.
If anyone has a line on an HDJ80 oil pan and oil pickup, I am here.
I also need to source the correct ECU for this motor/trans combo and the correct gas pedal assembly - still doing a bit of research on this front.
For those out there that are familiar with these engines - if I’m missing any ‘while you’re in there’ items that are easiest while the engine is out, give me a holler!
A750F? You're going to love that transmission. It's 2nd thing that I miss about my Sequoia.
I'd personally mount the EGT probe post turbo so that if the probe breaks, it won't frag out the turbo.
The biggest headache for me is dealing with wiring... already. Lol. Don't depend on anyone in AUS to provide a ready built harness that's plug and play with any automatic transmission. Ive had conversations with all the big names, mick fte, thrashlux, and a few others.
It all comes back to the same outcome, a lot of money, for something that probably isn't exactly what you want or are looking for. Most of the require the 80 loom, and maybe the hdj loom, they also require you to run an aftermarket TCU like compushift.
Im calling boostec next week maybe to see if they have a TRUE plug and play harness for a LHD 80s series conversion, but im not holding my breath.
Ive bought two wiring classes, a bunch of wiring supplies, because I feel like im going to be doing this myself in the long run.....
@lelandEOD , tried to warn me about this also.
The EGT needs to be pre-turbo to accurately monitor the exhaust gases to see what load the engine is under. They don't just break off.
Awesome info guys. @Mag71k5 I’ve been treating @lelandEOD’s conversion thread as a guide as there’s some really good info there and by a roll of the dice, I happened to find the same engine and trans combo. It seems like the A750F is controlled by the ecu for that setup.
I'm not afraid of a little wiring, so my current working idea is to have one of the harness builders setup an engine-to-body harness for me, and I will modify as needed to get it the rest of that way. How painful that will be l don't know yet.
There's also a little devil on my shoulder whispering that I should just manual swap it at the same time - my gut says that would simplify wiring and I sure do love a manual.
I've been finishing up some house Reno work and traveling for my day job a bit so haven't made much progress here. The other day I did pull the pipes on the compressor side of the turbo to check for shaft play.
No in/out play, and a hair of side/side play so the turbo seems in order. It also appears to be a non-VNT variant. I don't see any Garrett stampings.
Compressor wheel was a bit grimy so I cleaned with q-tips.
Currently waiting on a large order to arrive from partsouq and also some longer m12-1.25 bolt to get this heavy pig into the engine stand.
Managed to sneak in a few brews and do a valve adjustment after getting the engine in the stand last night.
Set back to the FSM specs :beer:
Also got a shipment from PS - timing belt & related items next
Awesome work so far, I'm surprised the valves were that out of spec with the low amount of miles. Is that normal for these engines? I haven't really researched it, and I aim to do the same when I pull mine.
I’m not sure if it’s normal, but the engine was from a service vehicle of sorts, so my best guess is that while the miles are low, it may have seen some idle time. They were a little further from the spec than I expected.
I would totally recommend doing it while the engine is free of a vehicle and harness and is in a stand - makes it a bit more comfortable. The FSM has a really nice detailed procedure on this.
This is an excerpt that I used:
https://toyotamanuals.gitlab.io/landcruiserjul2009/rm/rm617e/m_em_0009.pdf
Small update here, did the timing belt, water pump, tensioner, cam pulley and t-stat last night. She should be ready to roll. :cool:
Oh and I carved out what seems like a pound of very fine dried silt from the back of the fan pulley and from the harmonic balancer.
Next will be oil pickup and pan. Working on sourcing those now. Sounds like Dave over at japan4x4 has a hookup (thanks for the recommendation @ikarus). Need to source an EGT sensor setup, was thinking something like this. Open to suggestions if there’s other options folks have liked.
I don't have a FTE but I do have the FT and a H151 Transmission. I would without a doubt only do a manual transmission. I have used 1st gear down many steep grades and it put zero wear on the brakes while being able to shift in anticipation of mountain passes and climbs. Its easier and a better fit IMHO
@SteelHunterFJ80 I'm still going back and forth on it. I don't have a manual trans vehicle any more and miss it. Would be super cool in an 80.
Also, a year ago when I thought I was going to be a reasonable person and leave the engine in the 80 as it is, I regeared the diffs to 4.56's. Made a nice difference with the heavy tires, but i fear swapping in a h151f (not to mention sourcing it) would spin the FTE quite a bit on the highway when hauling some a$$.
I suppose i could always overdrive the hi-range in the t-case, re-gear the diffs again, or simply get larger tires.
I threw this together a while back when kicking around some ideas:
Curious, what diff ratios are you running and tire size? What's your engine speed when clocking 80 mph down the highway?
I also wonder if 2630rpm in 5th @ 80 mph with the auto 5 speed is a bit overboard since the FTE should be into the torque by say, 2k rpm.
Amazing project!
The manual is great and probably better in the mountains but for everyday driving and stop and go traffic, the auto is the way.
The big thing to address is the wiring. ECU/spill valve/fuel pump and throttle. they have to match applications. Someone could verify this, but I don't think you can mix 70 series and 100 series parts.
on my 80, it was all 70 series (pedal/pump/ecu and wiring sockets)
are you redoing the factory wiring or sourcing a kit?
All powertrain donor parts have come from a 2005 HDJ100 - that includes engine, partial engine harness, fuel pump, spill valve and spill valve controller, trans and t-case.
Parts that did i didn't get with the drivetrain:
-late 100 series pedal assembly (ordered and on it's way) from partsouq
-ECU (i believe i also need a specific ECU given the variations of the 100 series FTE), VERY pricey on partsouq
-other half of the engine harness that connects the the body harness - the salvage yard just hacked it where it was convenient :bang:
For the wiring, I'm inclined to ask one of the harness builders in Australia to build me a conversion harness and if there is a connection here or there that I need to modify, I can do that. I'm thinking that pathway might help me hold on to my last bit of sanity.
With 3.583:1 and 33inch tires the gearing feels good overall but pretty sure I'm already over 3000rpm at 80 mph so with 4.56:1 it should be much higher, probably closer to 4000rpm. H152 with longer 5th gear would be nice for highway speeds even with standard gearing.
An FTE has no problem running 2500rpms give or take down the highway all day long.
H152 trans, 4.3 gears and 33” tires 70-75mph is the sweet spot for mpg and rpms. 80mph with 4.10 gears and 35’s is also a sweet spot. Same for 4.3’s and 35’s, it’s in the 70-75mph range.
Also no problem doing 3,000rpms passing on the highway ect with an FTE. I have done a little over 90mph in the combos above passing on the highway, these being brief pulls up to 3,000 and holding that for 30 seconds or so before backing off.
Cheers
Great to know. I plugged in these few setups above to see what cruising rpms come along with these.
Based on what you're saying, it sounds like the FTE is most efficient in the 2300-2500 range.
