1FZ-FE poor cold starts and wont idle (15 Viewers)
Got the car back from the mechanic. He said the issue was that the LPG system splices into the factory oxygen sensor wiring. However, someone in the past has removed the stepper motor for the LPG system, which means it now runs open loop, and doesnt need any o2 input. The splice connection was twisted and taped, so it would sometimes send dodgy signals interfering with o2 readings to the ecu when running on petrol.. thats why it was running good for a few weeks, until it wasnt. He's now disconnected the LPG wiring to the o2 sensor circuit and terminated it, so it wont happen again and the car is running good again... for now.. haha.
Glad you got it sorted
Spoke too soon. Still playing up for the first 5 mins when cold on petrol. Bogs down, low power and slighty lumpy idle. After 5 mins of driving it's fine. Also runs fine on LPG. Next step will be to clean the injectors and inspect the fuel pump. Unless this is electrical related..then I'm stumped.
bugger. At least it settles down after 5 mins
bit of an update:
I backprobed the ecu and following sensors, tested for continuity and also voltage during operation:
  • Engine coolant temp sensor - passed
  • IAT sensor from air flow meter - passed
  • Idle suction control valve - passed
I installed the second hand idle air control valve to see how it would affect the cold start RPM. It does idle a bit higher than the original one, but not as high as they normally do when cold. It looks like someone has opened up the original IACV. The 3 screws have been removed using vice grips as all had rough edges and damage around the head of the screws. Additionally, the shielding to the wires at the connector have been damaged (possibly the auto electrician in Newcastle when installing the loom). I tried to paint some liquid electrical tape over those areas, but it was very tricky given the limited amount of room to work. At least 4 of the 6 wires had been damaged. They all seem to pass continuity tests though, which is a good sign.
I also noticed some white writing up under the intake manifold. To my knowledge, the manifold had never been removed, but maybe I am wrong. Normally wreckers/scrap yards would do that when selling parts, but why on earth the intake manifold would ever need replacing, I have no idea, unless the auto elec removed it to make installation of the new harness easier and left notes to himself.
At this point, I'm at a bit of a loss. The car will consistently bog down when cold running on petrol/gasoline and clears up after a few mins of driving after it warms up. It will not do this starting and running on LPG—certainly sounding like a fuel delivery issue.
Next steps:
  • re-test fuel pressure (this was previously done and passed)
  • on vehicle injector clean (via some machine my mechanic has, that cleans the injectors without removing them).
The car has 152,000kms and is on the original fuel pump. I confirmed the hatch has never been opened.
Hopefully this will give us some further clues. If the original pump is okay, I'll still be replacing the hose and filter sock as preventative maintenance.
for those curious as to what the IACV idle air control valve looks like dismantled.
