^^^^^this^^^^^
They quoted me $1105 plus shipping before the Corona Chan happened...however they will honor a military discount for $55.00 off.
yup. I got about the same price, but ordered 2. For me & a friend. Saved on shipping too I believe.
^^^^^this^^^^^
I think thats the one I ended up with!
Those are my excite upgrades coming. Along with new oil gaskets, distributor, rotor, cables, power steering reservoir, battery cables, etc. Then its onto suspensionCrazy b/c I replaced all hoses, thermostat, wits end blue clutch and installed a water temp sensor (glowshift) on the upper rad hose. I'm getting 180-183 city driving temps, doesn't go above. Not sure if that's the accurate "real temp" but I stopped looking at my dash temp lol
Those are my excite upgrades coming. Along with new oil gaskets, distributor, rotor, cables, power steering reservoir, battery cables, etc. Then its onto suspension. I also got the Ultragauge unit that plugs onto the obd2. Curious how that will work.
I’m replacing the same. Any tools or techniques that you suggest to keep the cuss words to a minimum?Going to be fun, goodluck on the PHH bypass and rear heater bypass part. You'll learn new cuss words. HAHAHA
None of this is rocket surgery and not even all that inconvenient. Remove the drivers side front tire and the rubber splash guard to gain access. The smaller you are the easier the PHH job will be. I routed my section of hose from the head up to the hearer valve inboard of the brake booster. This is actually easier than doing a standard PHH replacement because it eliminates 4 clamps. It should take no more than 30 minutes once access has been gained. The rear heater bypass is a piece of cake.I’m replacing the same. Any tools or techniques that you suggest to keep the cuss words at a minimum?
I realize that this thread is years stale, but since it was helpful to me, thought I'd share my radiator story. I went with El Cheapo from Amazon for $250. The Ron Davis unit is now $1,500, so that is out of my price range
Amazon title: "4 Row Aluminum Radiator For 1993-1997 94 95 96 Toyota Land Cruiser LX450 4.5L L6 AT MT 93-94 95 96 All Aluminum Radiators"
Here is my review:
The radiator looks much thicker than the stock unit and hopefully the welds hold up to off-roading. Most welds look really nice, only exception is the filler on the top. The other areas where hoses attach are slightly off with their angle and length. Some, like the overflow are an inch off. Others like the top hose to the engine are at an angle that is slightly off and it puts tension on the hose that was not there before. It is installed and works, but I am concerned about these compromises over time
I know it’s only been a few months, how’s the radiator working for you? Any average temp differences?
Glad to hear. I am soon to be in the market for a new radiator and I’ve heard get metal. Someone replaced the crank seal before I got it (not a LC person because they didn’t replace the oil pump seal) and beat the radiator like a red headed step child.Hi @dturner , I have been on several off roading trips since replacing my radiator and the new unit is holding up well. On my last outing, it was 117 degrees and there were no overheating issues. I never had overheating issues with the stock radiator either. I did notice that the new radiator takes more coolant than the stock unit, so the extra volume is likely an added bonus. I agree that it would be nice if some adjustments in manufacturing were made to avoid stretching the hoses. I hope the new radiator treats you well.
I just went through some discomfort with this company. They sent me three in a row with the exact same defect. They say they will refund me, but blame me for being too picky since according to Mike, "every radiator comes with some minor imperfections." Would you accept this for $500? Also, they told me it was heavy duty all brass construction.Cruiser corps has an OEM reproduction
Radiator - Reproduction - FJ80 1993-1997
Fits 1993-1997 FZJ80 (Toyota Landcruiser and Lexus LX450) - Replace your cracked, leaky, OEM radiator with this High Quality, Heavy-Duty aftermarket 3-core radiator. Your Landcruiser's engine will thank you! This is a direct bolt-on unit that includes an OE style integrated transmission oil...cruisercorps.com
here’s a couple part numbers also
1993-1994 FZJ80 Brass 3 row Radiator: 16400-66040 (will fit '95-'97 also)
1995-1997 FZJ80 2 row aluminum radiator: 16400-66081 (for reference)
That is clearly shipping damaged, looks like that side was impacted/ dropped during transit due to insufficient protection. I have seen OE Toyota radiator for 200 series distorted picking up from then dealer as well but as severe. But 80 series OE unit usually good if packaged well. Most vendor doesn’t do a good job unfortunately.I just went through some discomfort with this company. They sent me three in a row with the exact same defect. They say they will refund me, but blame me for being too picky since according to Mike, "every radiator comes with some minor imperfections." Would you accept this for $500? Also, they told me it was heavy duty all brass construction.
As you know, obviously not brass.I just went through some discomfort with this company. They sent me three in a row with the exact same defect. They say they will refund me, but blame me for being too picky since according to Mike, "every radiator comes with some minor imperfections." Would you accept this for $500? Also, they told me it was heavy duty all brass construction.
