Are you going to "Lap" the valves? If so, you will need some valve grinding compound, a suction cup on a stick, new valve guide seals, and the tools to remove / install valve springs. You should also get some new valve shims in order to measure your valves and make sure they are all the same. This is frequently done with a spring compression gauge to measure the spring rate at a given height, then shim to get the correct pressure.
Good Luck!
Congrats on rebuilding the injectors! Did you do it all on your kitchen table?
You've already taken on more than I am willing to do anymore! However, with the amount of inflation you have stated, necessity is the mother of all invention! I would do it, too, if I had to due to not enough money and the quality of work you get outside.
When you're done, maybe you should farm out YOUR skills as a mechanic....you can certainly do a better job than most!
Good Luck!
