Builds 1993 refreshed (now gone) and 1995 build up with new OEM engine (6 Viewers)
Many things going on and done.
Old vs new
Rear heater delete and it was soooooo crusty under everything I had to give it a clean.
Cheers
Lots going on today but only a few pics for now.
Getting the high pressure line in plus pulled the cooler lines and cleaned them.
Put a quick alignment on the front end so as soon as I clean up the mess under the truck I am slapping wheels back on it and setting down.
Cheers
I was bummed to find this when I pulled the mud flap. No worries though, got a new OEM located for cheap and have had a plan for my flares all along when I get to that point.
I got a new TYC condenser coming with a new Denso A/C compressor from CoolStream in Arizona so pulled the old one.
Need to pull the trans cooler and clean it, sure will make stuffing the engine easier.
It’s back on wheels, tiny ones but that is intended. 😉
Cleaning everything as I go and work through it all.
Cheers
I lied, two more pics. The start of a wood grain delete.
Man it is funky under this. Whole truck will get the delete as time allows.
Cheers
Got my items in today I needed to give the harness and EGR just a bit more protection.
So now the night session starts on my junk.
Cheers
I got my rear brakes finished up last night.
Got the extra heat wrap on the wiring harness.
Got my EGR stuff sand blasted and painted with 1800* paint as well.
Cheers
Something else to consider is wrapping the EGR tube with that fire place door gasket/thick yarn looking and feeling stuff in an attempt to contain the heat first.
Where did you get the rear brake calipers?
Calipers: remanned piston side from Toyota, floating side also from Toyota but new.
Cheers
I am beat, so I decided no night session today. Came home to relax for a change at 730. 🙄
Cheers
