Builds 1993 refreshed (now gone) and 1995 build up with new OEM engine
New booster and master are installed.
Cheers
Another late night in the shop working on my own junk after hours.
Started in on upper manifold and did some little things to the engine. I am finding I am missing some things here and there. A few crush washers, a hose here and there, some bolts, a few clamps and so on and so forth. This is what we call the nickel and dime part of a build. Ordering up what I need, cleaning as I go...blah blah blah. Yup, I am super OCD, especially on my own Cruiser. 🙄🤪😄
And oh man, it’s going to be hot in the shop the next few days. 🥵
Cheers
Old vs new
Anti-seize on all splines.
Those of you new to Cruisers, pitman arm to box alignment is marked.
Inner firewall side of column, rag and u-joints plus new firewall seal installed.
Cheers
Redhead rebuilt box with 105 sector shaft and pitman arm. New mounting bolts and nuts as well, torqued to 105ftlbs.
Lower column and unjoints.
Cheers
Another long day in the shop working on my junk, didn’t take many pics though.
Good shape for 25yrs old but still hard as a rock and one has some small cracks.
Cheers
Nice and rust free Cruisers are always the best to work on.
Going in
Cleaned before pulling.
Old, I got the new ready to install but it seems I am missing the fuel pump cushion so it’s ordered.
Tank is nice and rust free but the fuel is old. I will drain and put in fresh gas before firing it up.
Cheers
So I am going to paint my EGR pipe with 2000* paint and wrap it with some high dollar heat wrap. I needed to order a bunch of wiring stuff for @jmlockwood build, which I did this morning so got what I been wanting to buy for the new harness around the EGR. Some pretty high dollar heat wrap-sheathing.
My to-do is shrinking and I am going to postpone a few things as well. Got some wheeling trips planned before winter, it’s not like I haven’t wheeled a stock Cruiser before!
Got a new alt and starter in route. Need to order a new A/C compressor. Not sure I will be ready to stuff the new engine in this weekend, if not the following weekend for sure.
Cheers
Had to go get some of this after work.
Then back in the shop to work on my own junk. New fuel pump, hose/clamps, pickup screen, cushion and sending unit.
Reinstalled with new crush washers and a new gasket.
To compliment the new throttle cable, I installed this.
Cheers
Going in
Cheers
Whats a new FP run now a days?
Any suggested mileage replacement for PM.
Did you have to supply redhead with the 105 shaft? Or did they acquire it themselves?
I supplied the sector shaft and rebuild kit.
Cheers
