1992 FJ80 Turn Signal and Hazards Issue
Columbia, SC
What started out as a "simple bulb swap" has turned into an avalanche of parts replacement, detail cleaning, and trouble shooting keeping my daily driver a driveway queen...
I have a 1992 FJ80 with no modifications aside from an ARB bumper (lights not connected) and a dead Pioneer head unit. Headlights, tail lights, and turn signals worked from the day I picked it up in June until Thursday of last week when I opened up the dash to upgrade some dead bulbs in the gauge cluster, specifically the "D" light and the cluster backlighting. Right now the dash is apart and I am testing the interior bulb replacements.
So here's the issue:
1. When the turn signals were replaced, LED 194's were thrown in there without thought to the need of an LED flasher. When they didn't work, it was thought polarity was the issue and therefore the polarity of the LEDs was adjusted only to find they didn't work and ultimately the realization that "Oh, they need the LED friendly flasher to work" struck.
2. Not having an LED friendly flasher like the Novita EP36, two 194's were placed back into the turn signal ports on the gauge cluster. With no change in status, it was assumed that perhaps I used expired 194 bulbs. The two bulbs were pulled and two others were put in. Again, nothing.
3. Out of curiosity, the turn signal switch was function tested fearing that perhaps it was struck to hard in the process of removing the dash... The lights obviously came on with a flick of the switch and they got bright with a pull of the bright/dimmer switch. It seems that the Turn/Light Control/Dimmer controls are good.
4. Picked up a Novita EP36 from O'Reilly's and pulled the original Toyota relay. After moving the U-shaped adapter, the Novita EP36 was placed back into the relay seat and connected to the board. Replaced the two incandescent bulbs with Sylvania 194 LED's and tested. All lights except the turn signals work.
5. After reading more Mud posts, I decided I should take the flasher switch and connect it to the harness and see if the flashers work. Nothing.
6. At this point, I reflected on the advice of grey haired sages of old and decided to check the fuses. Knowing I had replaced the fuses that came in the 80 within a weeks time of buying it, I wondered if that could be the issue. The 7.5amp "TURN" fuse in the dash was intact. The 15amp "Hazard/Horn" is intact. The Horn/Hazard relay works.
I am at a loss here. Vehicle electrical is honestly not my strong suite.
1. Within the next 24 hours I plan to check for a ground on the driver's kick panel.
2. Re-check the fuse under the hood.
I've searched the forums and have not found anyone with this exact issue or similar circumstance in an 80 Series. Has anyone had this issue or have any experience with these things? I need all the help I can get.
Do you have a voltmeter? This would be the easiest way to diagnose whether or not you are getting power to the socket. It sounds like a ground issue.
Also, the sockets get corroded. Some fine steel wool will do the trick on cleaning them up. Spray steel wool with some WD40 and wipe out the socket. Dry with paper towel.
The sockets for the 194 bulbs on the gauge cluster look like new as well as the connections for the cluster itself.
Are you referring to the actual turn signal bulbs on the exterior of the vehicle?
Yes. Sorry, I misinterpreted your entire post :rofl: as it was before my coffee!
There are some posts here that describe not being able to see certain dash lights in daytime, only at night due to their low illuminicity. Best of luck!
No problem! Still isn't a bad idea for me to do!
Yeah, I think I have the dash switch illum issue headed in the right direction, it's the lack of turn signals and hazards that is a major issue. Going from working excellently to not at all in an hours maintenance time is a bit concerning. I'm not sure if anyone has experienced this issue with their 80 before and if we do figure it out, it'll make for a good reference post.
have you tried putting the non leds back in and see if you have the same issue
Yes.
In bullet point 2, we realized the point of putting LED bulbs in the gauge cluster's turn signal spot was mute until an LED flasher was installed. We pulled them, then reinstalled two incandescent bulbs for the turn signal/flasher on the gauge cluster. We still did not get any indicator flashing on the cluster.
Now, the EP36 flasher is in stalled with two LED bulbs. Still nothing.
I like the BaT style phrasing in the op haha. Before anything, did you disconnect any grounds or harness connections that were not redone at the time of testing? If not...
Gotta isolate which side of the relay the issue is on, so the big question is do you hear the flasher relay (old or new) clicking on and off?
Yes.
Did you ever figure out what was wrong?? I'm having similar issues with my 1990 80 series... All fuses are good and the relay has been replaced, but turn signals refuse to work 😭
