1989 FJ62 radiator replacement (1 Viewer)
need to replace my radiator leaking due to rust. Any recommendations with brand and part #. Thanks
I got mine re cored at a local shop a couple of months ago. Time will tell how long it lasts, but they seem to do a good job.
Go with the CSF 2708, which is the radiator for both the FJ 60 and 62. Since you have a 62, you will be using the trans cooler. Another mud member had a bad trans cooler in his CSF radiator and it took out his transmission. So just have it pressure test before you install it.
Zack
x2 on the CSF 2708. I replaced mine a few months ago, works great. It's a drop in replacement. The inlet and outlet necks are a bit longer but it doesn't cause any problems. Also no bracket on the bottom to hold the tranny cooler lines, but again, no problem.
There are several (long) conversations about choosing a new radiator already on Mud. Using search will find them
Cruiser Corp has one aluminum radiator left.
