- Thread starter
- #321
Had an interesting turn of events after talking with another local auto electronics guy, who seemed to be a toyota specific dude...
It took him about 5 minutes of reviewing the wiring diagram before he successfully troubleshooted the current problem
The conclusion.....the alternator rebuild failed for one reason or another and it needs to come back out...
Here's to doing this one more time and hopefully never again
**** Now, the big question. Am I really going to lift my engine again so I can remove the alternator bolt, or am I going to drill a big ass hole in my wheel well to gain access. I wonder if that's a structural issue...it doesn't seem like a good idea
- He focused in on the L connector on the alternator, since that circuit seems to relate to all of the dash lights, as seen in the wiring diagrams above
- The L is supposed to be hot, and when active it grounds out and completes the circuit, as seen in the charge light relay above ( I may have that backwards but you get the point )
- When power passes through the charge light coil relay thingy, its supposed to close that circuit and then send power to everything else down the line
- I removed the wire harness from alternator, and supplied a ground wire directly to the L port on vehicle side of harness
- All of the dash lights work again
