- Joined
- Sep 4, 2020
- Threads
- 138
- Messages
- 2,054
- Location
- Brunei Darussalam
- Website
- eurasiaoverland.com
I would guess it's the first muffler box. Toyota often don't list a separate 'converter' if it is part of a downpipe assembly.
hey ! that's the dude from monkey magic
Another random question in regards to power steering .
The cap cals for " Dexron type power steering fluid "
I always associated Dexron with red ATF fluid and power steering fluid being oil colored
I pulled the dipstick and checked , it appears to be oil colored and looks clean so I wont mess with it BUT im curious what fluid should be on the system when it calls for " dexron type power steering fluid " based on color I assume keep using regular PS fluid and don't use ATF
OK cool, good to know. Ill just run the 10w30 for now based on temperaturesVehicles like this don't use anything fancy for fluids.
Engine oil just needs to be diesel type (detergent level) and viscosity is dictated by climate (temp range). A 10W40 is a better oil (wider temp range) than a 15W40.
Coolant is green glycol.
Power steering is ATF Dexron III
The squealing belts is weird. If it was rebuilt 5k miles ago it wouldn't need new ones. But the rest of the engine looks clean enough to support the rebuild claim.
Good to know. I see that Shell claims the 15w40 is rated down to -13F.Congratulations on the purchase! Looks like you've got a sweet little commuter. Regarding oil I would recommend Shell Rotella T6, either 15W-40 or 10W-30 depending on the recommend viscosity and operating temperature range. It is inexpensive, synthetic, and has a good reputation. I've been using it in all my diesels for years now, used oil analysis has always recommended 8-12k mile changes with it.
I would definitely have a close look at the timing belt, if it has really been 10+ years it would be worth replacing for peace of mind. I can almost guarantee it is an interference motor, it would be pretty much impossible to build a diesel that wasn't due to the compression requirements. A broken timing belt will result in bent valves, dented pistons, and likely cylinder wall scoring and bottom end damage.
I'd love to come check it out some time when I am back in the Flathead if that would be ok.
Great info thanks for sharing the above
So I wonder if I should open up the timing belt cover since im so close already . I want to inspect the belt but then again I sorta dont want any trouble.. . Hmmm
No manual unfortunately but the cover appears to be a two piece unit. The top seems to have a few clips and 2-3 bolts and i was thinking that may reveal something . But im not sure and probably wont mess with it...yeah there is a nice way to access the crank from wheel well.I don't think you're very close to getting the cover off - you'll need to deal with the crankshaft pulley bolt (do you have access from the RH wheel well)? Looks like you'll also need to remove the cruise control assembly at least in part, possibly a power steering hose. Do you have a workshop manual?
Oil Viscosity Info
Just to confirm what most people already know. Mobil responded to my inquiry in regards to temperature ranges for different oil viscosity. I think I'll plan to run 15w40 and leave this rig parked if it gets below 20 degrees outside. It looks like if I want to run it in colder temperatures I should go with a 10w30
I can't find your engine either, but for diesel engine oils with CK-4 specifications (assuming your vehicle is CK-4 technology), the suggested temperature ranges generally follow these guidelines:
- 10W-30: Ideal for moderate to cold temperatures, typically ranging from -20°C to 30°C (-4°F to 86°F). It offers better cold-start performance.
- 15W-40: Suited for warmer climates, with a range from -10°C to 40°C (14°F to 104°F), providing excellent protection in high-temperature conditions.
Good call, I see Shell Rotella has that option but Mobil Delvac does not. Yeah that sounds like a happy middle ground I'm just trying to make use of this 5 qts of 15w40 in my garage lolOr you can run a 10W40 which will happily do -20C to +40C ambient. I find 15W40's crank slow below zero.
