Actually the lower (pink) BVSV is part of the choke opener system. When the engine is hot the choke plate is automatically pulled open to prevent an overly rich fuel to air ratio.The lower BVSV works with the Air injection system (air pump) to reburn exhaust gases. If you have no air pump, air injection rail or abv...you don't need this. Also it works with the cat and the air injection computer...if any of these are not working ...like the temp sensor on the cat....then you don't need it.
My engine is partially desmogged...(no air pump, no air rail, disconnect abv) and I have disconnected from the lower bvsv.
Ok...but is this in addition to working with the AI system?Actually the lower (pink) BVSV is part of the choke opener system. When the engine is hot the choke plate is automatically pulled open to prevent an overly rich fuel to air ratio.
Looks like they share the vacuum source side of the BVSV, not the controlled side of the BVSV.Ok...but is this in addition to working with the AI system?
this image shows the lower working with the AI...
