1974 FJ40 Calipers what year?
Website
www.valorbound.com
Poser
Oh...Durka Durka Durka.
Supporting Vendor
MN
Being that the 1974 40 series did not float over here with disc brakes, someone has installed something custom and since there are more than one way to put disc brakes on the front axle of these vehicles, you should probably post up a couple pictures of your current caliper and rotor combination so that your caliper can be identified and the correct suggestion made as to what you should purchase for a replacement....
:beer:
Website
www.valorbound.com
ok will do thx!
Website
www.valorbound.com
Pictures please tell me what you think i need to order new calipers
Ok so what year are these suckers???
Website
www.valorbound.com
posted the pics take a look i see a wierd stamp then a 7 6 not sure if that means its a 76 oddly enough its easy to see in the photo not so easy to see on the actualy caliper.
Poser
Supporting Vendor
MN
Groovy, vented rotors.
Land Cruiser disc brake rotors and calipers.
Order calipers for a 1980 40 series and you will be fine.
:beer:
Strictly going on the backing plate/dust shield, that component is from 08/75-07/80 as you can remove the junction block bolted to the back of the shield for the hose from the axle and tube to the caliper.
08/80 and later were held in place by two rivets and only had one bolt holding the other ear on, because of the stiffener bracket that is held on by the caliper bolts and bolts to the top and bottom of the shield.
But unless you post up pictures of the rotor/wheel bearing hub assembly without the wheel spacers, I will not be able to tell you what year your rotors are. (08/75-07/80 or 08/80-01/90)
Website
www.valorbound.com
youre the best thx man!
