1966 FJ45 PU Build (1 Viewer)
Zionsville, IN
1966 FJ485 PU Build
I just purchased a very rough 1966 FJ45.
The condition is pretty bad the pics will tell the story but what I'm looking for is some ideas of what kind of build you would do with this basket case. Since there is nowhere near enough good metal to restore this girl I won't feel bad cutting her up.
I'm thinking of making it an extra cab or maybe even a 4 door(4 doors are coming with it). I'm also 6'5" so the extra room is needed. I'm even contemplating fixing the bed to the cab and doing something like the Avalanche where I can add or remove a section to open it up all the way or close it off like a truck bed.
Next would be the engine, I'm thinking 1HD-T(HP 162 and TQ 267 seem a bit low?), Torfab says he has one with an a442f. I like the idea of the 2uz-fe with the 5 speed auto out of the 100 series. I'm even contemplating an LS2 6.0 (actually an L96)with an Allison transmission behind it(I work for Allison and would love one in a rig)
Next is the frame and axles, the original frame is shot and the back half past the wheels has been cut off. I'm thinking an 80 series frame and axles from a locked rig so I could use the harness and switch for the electric lockers.
Next is the suspension, very likely I'll be moving to CO and this will be my wheeler, but also see street use. I'm thinking linked & coil overs maybe even up through the bed like I've seen on 80 series.
Really the only useful parts are the front quarter/cab and the truck bed sides.
I think that is the basics so throw out some ideas for:
General direction for the rig, where to start?
Engine & Trans
Frame & Axles
Suspension
Pics are always helpful, links to built 45's
I'm leaning 1HD-T and a442f but open to suggestions. I like the "keeping it Toyota" but a Hino j05e and an Allison could probably be done. Don't know if the expense will have any real benefit. Looking for ideas of a good cost benefit drivetrain. I've never driven a 1HD-T 80 series so I don't know how the power is on it.
That is rough but definitely doable. 1HD-T with 80 axles and frame with 37's is my vote
check out Aqualu for the four door cab body...
If I went with the stretched cab I would also get the shortened long box. Or shorten the one I have.
After seeing some of the BS you have to do to get the cowl to work I would get the 3/4 tub and rebuild a stock steel cowl. Which tub? I like the stretched cab if you're gonna wheel it. Though I guess the 110" WB is pretty nice overall to wheel if it's on 36" or bigger tires and sprung over.
Kinda cool seeing the whole truck set together though. I've never seen that pile of parts look that good! :lol:
Nick
Hey Nick, Thanks for helping with delivery. She doesn't look half bad all put together huh.
Obviously, you're going to run into compromises between wheel-ability and utility. The longer wheelbase for more room inside for backseat passengers or storage is going to detract from severe-duty wheel-ability. The extended cab with the shorter wheelbase is going to improve wheel-ability with the trade-off of fewer passengers and/or inside storage.
Personally, I'd go for the #4630 over the 4-door "SUV" models though...
FMTV seats...?
Info
Towel Bar Adjustable Fore/Aft Movement
Recliner
Contour Back
6.7-Inch slide tracks fore/aft movement
4-Point seatbelt
