- Thread starter
- #801
the short answer is yes.Quick question for you. Your fenders have the 3 holes for the newer style signal lights. I want to use the roud lights as you have done. Does the base cover the 2 smaller holes on the sides of the main mounting hole?
Great build by the way your an insperation!
Not yet. Still trying to flush out a couple of leaks. Will need to pick up another temp sending unit adapter. for some reason, can't get the one I have to stop leaking once the coolant is up to operating temp and pressure. have tried to seal It three times so Its time to start with another one. Also have a brake line that's weeping fluid Overnight. have to finish up the shifter linkage and get the rear bumper and lights reinstall after paint.Getting close, Had a chance to spin it around the block yet.
Yeah. Just up and down the street.I assume you took it for a spin, sure looks great.
Thanks Kelly. Thanks again for the glass template. Hope to get that glass cut soon.Damn Mike, they just don't get any better than that. Fabulous craftsmanship.
