GM 1956 GMC gets an upgrade or two!
General Motors, Chevorlet, Pontiac, Oldsmobile, Saturn
Finally some picture worthy progress.
I made a little progress this weekend. The upper and lower ball joint’s are installed. The u joints on the axel shafts are installed as well as the new rear brake lines.
I dropped the front axle off at the shop on Friday. He says about 2 weeks, hopefully that is an accurate quote.
When I was installing the u joints, I discovered that the “ears” on the inside right shaft are bent. Apparently I applied a little too much pressure during removal. Now one of the cir-clips can’t be installed. I’m reluctant to attempt to straighten it, as I think the metal integrity would be compromised. So a new one is on order.
Well it’s one step forward and two steps back. Late last week my axle guy informed me that the housing has a hole in it. I was gob smacked honestly. He said something had come loose and was shoved through the housing after making a mess inside. The PO had epoxied the outside and RTV’d the inside. The epoxy had collected dirt and appeared to be a dirt clod until the pressure washer hit it.
So I have spent the weekend searching for a replacement. No luck so far, but I’m going to look at another one today.
I ran a mission this weekend. I borrowed a mini skid on Saturday and this afternoon I retrieved the Dana 44 I found about 2 weeks ago but couldn’t get because of wet red clay.
The mission was a success. Nothing broken and nobody bleeding.
Dana 44 2.0 ready to go. The disassembly took significantly less time. I guess you can teach an old dog new tricks after all 🤷🏻‍♂️
My axel guy is ready to receive it next Monday.
Last Sunday it was sunny and 77* as I loaded the axle for delivery on Monday. The picture says everything that needs to be said about Monday.
While I’m waiting on the front axle, I decided to tackle the biggest sheet metal challenge on this project. I harvested the roof skin from a parts truck. Now I’m preparing the donor patch and getting ready to scalp the cab.
This wasn’t nearly as much fun as it would appear to be.
Measure 10 times cut once! Looks good!
The dirty deed is done. I drew my lines and started cutting.
The first cut was across the front. I almost had a heart attack when it literally started popping up as I was cutting through. I couldn’t imagine why there would be so much tension in the roof skin. Then I remembered why I was cutting it off to begin with.
I also broke in a new welding glove. After setting my Mechanics Wear glove on fire with cutting slag. 🤷🏻‍♂️
I removed the rest of the roof skin from the front edge of the cab. Then I wire brushed the inner structure of the cab and applied a rust reformer product. I also finished prepping the replacement skin. None of the inside roof skin will be visible with head liner installed. But I want a sealed coat of paint on it anyway.
Are you going to weld , bond or both?
J right now I plan to weld it. I’m not familiar with the bonding process.
