Hi there,
I'm getting ready to send my injectors to Rob Millson and noticed a few things I'll probably need after I get the m back. I've looked at the nice part numbers thread already. I'm just hoping someone here knows the part numbers or even better, a supplier...
First is...... the "Ring packing" seen on FU-10 of FSM (mine appear crumbly)
Second is.... nozzle seat...(same page, does this usually need replacement?)
Third is..... same page but is called "gasket." it's between leakage pipe and nozzle. Labeled as "Non-Reusable part.)
While I'm waiting for the injectors, I wanted to check out a leak(s) that is apparently at the intake and/or one of the injector pipes. There looks like small amount of oil seepage that looks like it's getting sprayed(a little bit) somehow by fuel...So, to the points...is it possible to get a new pipe if it's screwed? Where could I find gaskets to remove/clean/reasemble the intake manifold?
Thanks for taking the time to read this
