I tend to run a lot of little devices when making trips, and so got annoyed with only being able to plug in one thing at a time up front. No option to charge my cell phone, GPS unit, and have the power inverter all hooked up at the same time.
Anyway, I was in Fred Meyer's and they had a 3 outlet one that looked like it'd fit perfectly for $10. Even had the nice switch and LED on the side so I can manually flip it off if I so desire.
Anyway, enough chat. Here are the pics.
Cover cut. Was actually suprisingly easy, though it's *THICK*.
Location where it will go. TONS of room.
Strip on top of the cover.
Test fitting. Was nearly a perfect fit the first time, despite the odd curve.
Closeup of how it fits. There's some plastic sticking up on the edges, so it's not as clean looking as it really is.
I used some stuff called Repair Plastic to fill in the big gaps. I'll also probably drop some epoxy/glue to make it a really solid fitting, as I really don't want this popping out.
Over all it actually looks great. Except for one cut that I went a bit too long on you can hardly see the cut edges. My original plan was to spray paint it black (after roughing up the wood color), but I'm going to leave it for now as it doesn't really bother me.
More/Larger pics: Picasa Web Albums - Ebag333 - 3 Cigarette O...
The next step is to get a fuse block and wire it up. I haven't decided what size fuse to get, all three of these will be on the same fuse so I don't want to go too large. I'm thinking no more than 15 amps (allows for 3x5) but I might go 10. The cable run would be *VERY* short as I'm going to mount the fuse block right next to it.
