Hi All- Im fully aware this may be the most asked, annoying-ish question on the forum. (I’ve gone down the rabbit hole of reading countless threads and YT videos). HOWEVER, there doesn’t seem to be consensus for my situation.
I own a stock 2000 100 series Land Cruiser. Suspension is stock- no lift. I am upgrading the wheels and tires to something larger.
I purchased a set of Nomad Sahara Wheels (17x 8.5… 0 offset). I am now evaluating tires and I’m looking for the largest tires I can fit without rubbing. Thinking Falken Wildpeaks or KO2’s.
I want to avoid any cutting, or modifying the pinch molds. I’m also looking to keep the tire poke more conservative (want to avoid throwing rocks and hopefully pass PA inspection).
Sizes I’ve been considering:
275 70R 17
265 70R 17
255 80R 17 (I’ve been hearing good things about the pizza cutter style. I’m not sure if the 33” diameter will fit without rubbing… also still evaluating the look).
Would love your thoughts/experience on what will actually fit! Pictures are super helpful.
Also, I’m curious if anyone has experience with the 255 80R 17 handling poorly at highway speeds?? - I’ve red some things that suggest that and would like to verify if it’s true.
Thank you!
275 70R 17
265 70R 17
Thank you!
