Zero offset wheels and tyres?
UK, midlands
I'm running a 2 inch lift and have 0 offset steel wheels. Can I get 285 75 16s on do you think?
I have kutsnake arches on, probably to hide rust, and I'm not brave enough to peel them off just yet. Hence the 0 offset wheels.
Lift does not gain tire clearance on IFS. The suspension still works in the exact same range of motion, the only thing that a lift changes is the ride height.
You would not be the first to try 0 offset and 285/75's. It's not ideal for these vehicles but it can be made to work.
That's very true. I'm might be tempted and fit extended bump stops. I have the original wheels to fall back on if it goes wrong.. thanks for the input, that's really helpful 👍
