Found this picture of a standard sand tire for the 100 series. Hope this helps.
What offset rim would I need to run to fit this without cutting the guards?
Whatever he’s running.... lol..
Highly recommend buying three things in this order: at least 1 pair of maxtrax, tire deflators, and on-board compressor.
Story time. I was told by the locals in Hawaii when I went to drive on Polihale beach (the one referenced by OP) that "it isn't like driving in other sand." I had a rented JKU and figured "how hard can it be? I'll just air down?"
Well, I ended up driving my pregnant wife onto the part of the beach owned by the DoD (Pacific Missile Range is right there) and getting stuck. Guys with machine guns came out and threatened to arrest us and told us we'd have to come back to court in Honolulu, etc. I spent 5 hours digging the stupid thing out. Dropped down to about 3 PSI and ended up having to get one of those farm 6x6s to pull us out. Absolutely awful.
The sand is composed of little animal shells or something weird and sticky. It's very soft and very different. IMO, a significantly heavier cruiser on stock tires would have a really hard time. I disagree to get tall pizza cutter tires. For sand you'd want wide and floaty tires for max contact patch.
Ultimately, I ended up not getting arrested and they were lenient. But pay attention to those signs, too.
Well done, Kekoa 12 from Kauai Island in Hawaii, with a special interest in local mountain trails and Polihale Beach --
100 series performance in soft sand .
Your First Post awakened both the Tyre Dragon and the Tire Dragon and yielded 86 fire-breathing replies and counting!
Seriously, we all benefit from the wide-ranging discussion that followed in this thread, even if there was not universal agreement.
At the start of the thread, the actual parameters you specified were:
- your vehicle must function as a daily driver, and,
- your primary offroad use would be weekend camping trips to:
- remote camping spots in the mountains, and/or,
- a long beach called Polihale with super soft and usually very dry sand.
So that is pretty much your statement of the purpose of your vehicle. You know your locality because you live there. A quick look around the web reveals that Kauai Island is an interesting and impressive place -- http://www.soest.hawaii.edu/coasts/publications/hawaiiCoastline/Kauai.pdf.
Your question was, “I'm concerned the weight of the 100 series will make driving at Polihale difficult and maybe I should go with a 4runner or GX 470?” In other words “Will a 100 series be fit-for-your-purpose?” Not anyone else’s purpose. And on that question you sought opinions.
Answers without bias and prejudice in favour of the 100 series may be hard to find on a 100 series forum! I do know that my daughter’s Suzuki Jimny with a Gross Vehicle Mass (GVM) of 1,435kg (3,164 pounds) is easier on sand than my LC100 with a GVM of 3,260kg (7,187 pounds) – but I am not for changing!
So far, I have been able to make my successive Landcruisers – FJ45, FJ55, LC100 x 4 -- all work on all the sands encountered – but that does not yet include your Polihale Beach ….
I also live on an island. It is a bit bigger than Kauai Island. It has a coastline of 25,760 kilometres, or a little over 16,000 miles, with lots of beaches with many different kinds of sand, many deserts some of which were beaches or ocean floors long ago in earlier geological times, and, some fairly well worn down ancient mountains now threaded with many interesting trails. I have lived, played, worked and explored many of these places over the last 70 years and 3 months.
Like you, I am still very interested to learn and remain respectful of the opinions of others. My purpose statement for my vehicle is very similar to yours – but expanded slightly. It may be different to the purposes of everyone else who has replied but that is their right.
- my vehicle must function as a daily driver – the tyres I use must be good enough for ALL that I do as I have no interest in the expense and inconvenience of operating several specialised sets of tyres nor operating off-standard tyre sizes. Yes – it is a compromise but my tyres will remain as 275/65R17 or thereabouts which was how my latest LC100 was delivered from the factory 13 years ago. Yes – I know specialist tyres, profiles and sizes will perform better in the special circumstances for which they are designed BUT that always brings some other compromises. And the height adjustment provided by the AHC system is all that I need, so I don’t yearn for a greater tyre diameter.
- my primary off-road or rough road use would be occasional trips to
- remote spots in the mountains which may involve rocky or muddy trails, and/or,
- various beaches and deserts with all different kinds of sand and rocks, and,
- sometimes involving visits to all of these kinds of places in the same trip.
There are lots of important things with tyres. When it comes to sand, I think of three things:
- Footprint bearing pressure – must be suitable for the materials and surface over which I intend to drive. I am prepared to 'air down' to increase tyre contact area and reduce surface bearing pressure at the tyre footprint but if that is insufficient for some situation then I don’t go there in my LC100 (rare in my experience),
- Traction is important – with as little slip as possible, even in sand. Wheel spin in sand just turns the tyre into a very efficient excavator – and down goes the vehicle! When the differentials and frame are sitting in the sand nothing else matters much until clearance has been achieved. However, with gently applied torque, lugs can add to traction without much ‘excavation’,
The experience of nukegoat and the picture at post #17 in this string says that caution is very wise on your Polihale Beach. You will know best – but methinks the sand type need not rule out a sand-ready LC100. At post #4 divemedic was the first to mention that sand-readiness also should include at least a pair of Maxtrax (or similar recovery boards such as Treds, X-Bull etc), ‘airing down’ with tyre deflator, and carrying a portable or fixed 12 volt compressor to ‘air up’ on return to the highway. Very good advice for self-help if stuck in any kind of sand!
- The always-present risks of getting stuck – which eventually happens to many people including me – and safe recovery.
A snatch strap and the correct vehicle fittings could be added to the list – but can be very dangerous if not attached and used properly. Obviously, good cooperation and communication with another vehicle is needed for safe ‘snatching’.
Please don’t do this with a snatch strap:
Please take these safety precautions instead:
The articles by Outback Joe are long and require patience but are worth a read:
How to Drive on Sand
Tyre Pressure Guide
Good luck with your vehicle choice and enjoy your Island!
Thanks for the input. Yes, Polihale is the beach at the Northwestern end. It's a popular beach to drive on because it's so large (15 miles long) and one of the only beaches on island where you can legally camp in a roof top tent or sleep in the back of your truck. Most camping areas don't allow you to sleep in your car I assume to keep homeless people from living there in a car.one can debate endlessly about the tires...
Another big issue, though, is that there is sand and then there is sand!
It can make a night and day difference.
I have a bit of experience with some local beach sand dunes. The 100 does very well there, even at asphalt pressures. Not as capable as the 80 around steep dunes but pretty good. With minimal attention paid to dune profiles and the like, I'm a good shape and can go most places. On the flat, no problem at all. The sand is sort of coarse, more like salt than flour. I suspect most beach sand is like that.
Now, from my limited experience, fine powder sand inland can be a different beast altogether. Like very fine flour or powdered sugar, and could easily be a nightmare and take down many trucks. There you'd want to go real low pressure for example, and driving skills would be more important.
As to Polihale specifically, if it's the one at the very Northwestern end of the southern road it is such a wonderful and beautiful beach that I would rather not take my truck on the beach itself. But that is a subjective matter best not addressed here I suppose. Having said that, I remember going up to the last dunes row oceanside in sedan 2 wheel drive cars in fairly deep sand and did just fine, so I suspect the beach itself should be relatively easy too.
It was nice to see an argument that wasn't about Trump for a change.OP - if you got the tl;dr point
... Yes, a 100 series will be fine in sand.
As an aside - Run whatever tyres you want to make your dick feel bigger, chode or pencil will both get the job done
I don't think that will work here. Our parking spaces are already super narrow.View attachment 2138355
