100 Series Drawer Build (pics) (1 Viewer)
I took the design off of someone on here maybe ntsaint.
The carpet is speaker box carpet, probably not the most durable but it is cheap and easy to work with.
I did make a dummy panel to place over the slide when the fridge is not there.
That there is a brilliant solution! Very well executed. I like my original KISS drawers. But, a solution like yours could be just what the doctor ordered to cure my boredom during this whole shelter in place stuff.
Drawer update...
I installed the front faces and locking compression latches. Pretty stoked
Great build. Have you considered Raptor liner or similar? I carpeted mine and sprayed raptor liner on the fronts. Drawers are one my most enjoyed mods to date... I like having so much with me all the time and the clean uncluttered look they offer.
Yeah something of the sort. I don't have a good place to spray anything right now so anything I do would be roll on. I want a textured finish so bedliner would probably do the job but I have also looked at doing something with a little more give/rubber, like a marine coating you would spray in the bottom of a fishing/duck boat.
Really digging these set ups.
Monstaliner. It’s a bedliner with texture but smooth to the touch and no snags. I did my whole 100 exterior in it and will use it for my drawer build.
This is so impressive! I started following this build the day you started it and I'm for sure going to do the same with my truck! I love that little slide out table and the three separate compartments. What I'm going to do different for mine though is to use push to open slides so I won't have to use any latches, and finish it off in a gray carpet, similar to the ARB drawers.
Thanks! It’s been a fun project. I have definitely gotten a lot of help from checking previous builds on this forum
Thanks for the input. I have liked what I’ve seen of monstaliner before on small projects. I just ordered a gallon of Medium Gray
I'm in the process of building my drawers system and I have to say, kudos to anyone who has tackled this project themselves. Its deceptively difficult and not nearly as easy as it initially seems. :cheers:
Couldn’t agree more. Post up some pics when you get a chance
It's coming together.
I replaced the first pull out table with a 3/4 slab of something a little nicer than plywood.
Got the front wings installed, did some bondo work, got the first round of sanding done.
I also added threaded inserts for the L-brackets supporting the side wings as well as the front wings for easy removal.
Monstaliner is on its way... If things go well hopefully I can get it painted next week.
Dude, you gotta make up some plans with a cut list for this! Good call on what looks like butcher block material!
You got the best DIY drawers I ever seen. Better than the commercial one they sell.
