100 Series Ditch Light Mount Kits
reznunt
Massive Metal Shop
Supporting Vendor
SoCal
Website
massivemetalshop.com
A run-of-the-mill rigid ditch light mount can’t compare to the near-infinite adjustability of our Massive single/dual ditch light mount kit. Full rotating design paired with slotted mounting holes allow for almost any desired orientation. Run a single ditch light pair or switch to quads in minutes all with one mount!
  • 100% bolt-on… installs in minutes
  • Mounts to the factory hood bracket location
  • Zero to 180+ degree variable mounting angle for your specific needs
  • Single ditch light kit includes one L-bracket per side that installs either inboard or outboard for mounting adjustability
  • Dual ditch light kit includes two L-brackets per side to run two pairs of ditch lights
  • Slotted L-brackets (available with M6 or M8 slots) for fine tuning mounting height and position
  • All 304 stainless steel (shipped in raw finish)
  • Includes complete stainless steel hardware kit
  • MADE IN USA
Here are a couple shots of the mounts in single configuration with some random no name lights installed. Yes, they're big old honkin' lights... they're just for mock up. Still waiting on the BD S2's.
Kits have arrived! All preorders have been shipped. Order yours today at Massivemetalshop.com!
M10 slotted L-brackets have arrived! These are new options for the single or dual ditch light kits as well as the rear hatch light mount kit. If you plan on running Rigid, Baja Designs, KC, or any other pods that use M10 or 3/8" mounting bolts, choose this bracket option because these are what you'll need! M8 and M6 also available for smaller light mounting bolts.
All preorders with the M10 slot option ship today. Thank you very much for your patience and your support!
