Same exact thing as my 99 Contour SVT. They were absolutely trash.
Such a mystery why all the domestic car makers nearly went out of business right after that time period...
What do you mean by this?
Bummer. Our LX takes just a touch longer than you would expect to turn over and I am thinking it’s the starter. Ughh.Terminal Starter Syndrome = The majority of factory starters on 100's fail at somewhere between 90K and 150K — usually just worn brushes. Super labor intensive with most shops charging between 3-5hrs labor + parts. there are a few options for parts: 1.) Rebuild the original starter (about $20 for OEM parts), 2.) Buy a refurbished starter (DENSO only - don't risk using an off brand even if it has a lifetime guaranty—due to $$$ labor cost!) for $150, or 3.) Buy a new DENSO starter for $500. You will also need a gasket set for the intake manifold, which has to be removed to access the starter. Total PITA!
I ordered a refurbished DENSO and will do the labor myself for about $200.
This is definitely not purely rational as I have had the same thoughts as you but prefer the drive, safety, etc of the LC over the 4runner. From a purely value proposition it surely seems the 4runner wins as compared to the LC. There are just as many high mileage 4runner’s as LC’s in our first world environment.So, I have been lurking around here for a couple years. I am a Toyota lover and have owned 5. I currently have an 07’ Tundra that has been super reliable. I can do the majority of my own mechanic work. If money was no object I would pick up a LC for sure but for me I just don’t think it would be a wise choice. I could get a 5 - 7 year old 4Runner with low miles for a little over $20K. Just as reliable and can go anywhere I would go. No issue getting parts or doing upgrades. I go back and forth about this. I know there is nothing like a LC but I do think this is an expensive endeavor.
True, but I can afford a much newer and lower mileage 4Runner which means less maintenance cost.
Ain't nothing wrong with a nice 4 runner, just make sure its the same engine as ours v8 4 runner last gen and you have yourself an inexpensive beast.
Check out this video that has me lusting for a limited v8 4 runner.
