Oh yeah - glass
Could you cut and go in the top? Then plug with a rubber strip
That's a good idea. Cut a slit in the top of the window frame and slide the glass down. Do you think it would weaken the structure at all?Oh yeah - glass
Could you cut and go in the top? Then plug with a rubber strip![]()
the good news with this build - other than it being awesome, is when your done it will be worth well over $150,000!
wheres the rest of your troopy build?
I also ran into an issue with the front bearing retainer seal not fitting over the 1HZ input shaft. After some research, I sourced the proper seal.
Talk to me about this.....
Is it an early/late model H55f issue, or something special that I'll need to get ordered soon?
Dan
